Using USB STick instead of SD Card
Is it possible to use an USB flash drive reader as an SD card reader? Im trying to use CH376S to do this but its not working. Anyone can help?
  • You need to write a replacement for the sd card to use that. We have no support for that chip or any other usb converter. So no it is not possible unless someone writes a solution for it. Sorry.
  • Oh! Ok, thanks for answering tho! :)
