Enforce Postion Feature - how to control speed?
the enforce position feature works fine for me now with relative position.
However I am not really using it since it takes too long to move to position and take the picture and move back because of ouzing.
Why is it the feature does not use the travel speed for this? For me it is much slower than my hardware could do, or my usual travel moves are set to...
I could not find a setting in the 1.03 or 1.0.4 firmware. But I guess that is a repetier-server feature and probably not a firmware function right? Any way to control the speed?
Thanks!
  • The speed in server printer configuration for moves is used. So increase that and it will move faster.
  • that worked, seperate setting would be nice though. Having manual Moves at 450mm/s is quite fast for manual control ;)
