Print
I have cnc table when I set a file to print it will not print. It draws a line on the screen then stops and does not cut. Then is disconnects. Any advice for a fix?
  • Not without informations. Host just sends the gcode to printer (assuming file = gcode file). What happens depends on the firmware on the cnc. For cnc you need to enable travel moves as they do not extrude you will not see anything else.
  • It prints old files put nothing new
  • Then you do not generate the new files the same way you did for the olds.
  • Ok I will try it again thank you for the help
