Repetier server tool menu issue
Printer > Print tab.
The tool menu is hidden inside the box.
  • You see the scroll slider right side? Scroll screen up to see it. But I see the problem. Will add an empty space below to make it easier to access the menu in next version.
  • Testing I also saw that the 2 icon views are not affected by the problem. But my fix seems to work, so solved for next update.
    Hi, yes the scrollbar works well, but the menu should float on top of the box, right? I can use it, but I would like to report the issue to make it even better.
    Cool, you fix should also work. Thanks.
  • Yes it should float and with the fix I made for next update it does float. Problem was that I made the table responsive for smartphone use which caused this behaviour as a side effect.
