Printing only extruder 2
Is it possible to print only with extruder 2? If so, how?
  • In slic3r this is no problem. Select in object placement extruder 2 for the object.
    If slic3r des not add T1 or extruder commands without named extruder you can simple activate second extruder and then print.
