Hotend is always 13°C to Hot
edited February 2019 in Extruder & Bed
Hey Ho,
i just setup a new printer, first time Repetier to try the features.
Everything went smooth so far accept one weird problem.
The Hotend always stays 13°C to hot O_o
The Temperature drift itself is perfect, +-0,5°
I set the Temp via Octoprint to 70° it goes to 83°, i set it to 90° it goes to 103°
I tried the temp offset from Octoprint, no difference, always 13° to hot U_u
Any Ideas?
[EDIT]
I tried PID Autotune to 200°C but it turns of after 1-2 tries with a Errormessage "Hotend to Hot"
  • Temperature too hot means you exceeded the allowed max. temperature from configuratuin.h. You can increase that or run M303 at lower temp. e.g. 180.
    What I wonder is your limit of PID Max to 128. If you use 24V on 12V elements the limit is 64. Power = I^2 * R and I = U/R so voltage influence is squared!
    Would be helpful here to also see output over time in graph to see what firmware is doing here. I think your drive min of 40 is too much in your case. That is for heaters that go to 255. Yours is maybe 10.
  • edited February 2019
    You are right,
    I'm using both 12V Bed and Hotend, but just 1/2 the power output so you are right in using 64 as Max PID *Shame*
    And the last bit was the important part
    "PID drive min" lowering to 10 was still to much U_u got within 3°C with that... I'm at 8 now and it is spot on :)
    [Edit]
    so after 4 Rounds of PID Autotune I'm within 0,2° idle at 200° and within 0.5° Printing  B)
