Afinibot A3 upgrade problems
I have 2 A3's running 92.9 firmware and both have auto level issues. I decided to upgrade 1 printer to 1.0.4 and the printer works but I have problems.
1 - Z axis is off using steps/mm from previous config
2 - I can't move Z axis until I home it, X & Y I can move before homing
3 -  If I kill print job I can't move Z unless I do a home (2&3 likely related)
4 - In my display i will get a flashing ???? for my Z axis
5 - I now have to put offsets in the repetier software for my bed to be centered, it was centered w/o them before. Can this be done in firmware instead?
Motherboard is ZONESTAR and I have 5 button display
  • Please upgrade to latest 1.0.4 as I fixed some serious errors today, also not related to your problem.
    Blinking ??? in display means axis is not homed.
    #define MOVE_Z_WHEN_HOMED 1 would say to only move after homing. Guess yours is 1.
    Don't know the printer but what do you mean with centered? Extruder is in center if you send right positions. x min/y min and x length/y length define coordinates. Normally left front is 0,0 for cartesian printers.
  • Ok I will retry it.
    Why would it "un home" on a kill print?
    I left only move after homing unchecked but I will verify.
    Let's say I run a file I ran previously. It prints over to to the left and off the bed where before it'd be centered on the bed. I had to change these values. before 0,0 worked fine like these offsets were stored in the firmware.
  • Blinking ??? in display means axis is not homed.
    #define MOVE_Z_WHEN_HOMED 0 CONFIRMED
    This happens after I kill print. It seems to throw Z home out the window.
    The Z axis won't rise now. It will lay the first layer perfect (auto level disabled of course) and then Z doesn't go up correctly. Almost like its missing steps.
    Back to the auto level issue, why does it drive into my bed? Changing z-probe height does not help.
  • You start mixing firmware and host.
    You defined in host that bed size is 200x200x100mm with left front edge being 0,0,0. If that differs from coordinates defined in firmware center in host is not center for printer! Both must match.
    Check host scripts to see what it does on print kill etc. If it moves out of Z firmware might loose homing info, also I'd think it rather does not move.
    Regarding z probe - what does M119 return when open and what when being hit? If it does not change you might have wrong pin configured.
  • I'm at work no so I will confirm later.
    Regarding the M119, where would I find this value in host?
  • You send it in manual control and see result in log. Disable easy mode to be allowed to do so.
  • I just thought of something, my prox sensor is plugged into z max on the board. With it triggering that's telling the machine it's at max thus driving nozzle lower into the bed? Would flipping the switch states flip that?  Normally open to normally closed
  • Name of pins do not determine function. Only if you have confiured you have z max endstop on z max pin something would happen. Checking M119 should show that you have no z max endstop.
  • edited February 2019
    Ok I've pretty much resolved my issues except for this auto leveling.
    My sensor triggers around 4mm from the bed. When i use 4mm as Z probe height and do a G32 S2 I see values in the log while probing around 16.xxx mm and my extruder digs into the bed while printing. I've adjusted Z probe heights from 4 to -15 but nothing fixes it. What am I missing?
    Now a separate issue I'm having is skipped steps on the Y axis due to rapid direction changes on my model.  Please help
    Another pic...maybe not
  • How does homing work? Direction and sensor?
    For Y you need to reduce force to y motor or increase current to y motor if it is not already at limit. Don't want driver too get hot (which also makes you looks steps). You can reduce acceleration (800-1500 is normal, also many can run even 3000 if you do not need to move a bed). Direction switches is also critical, here lower jerk xy values reduce the speed at corners and forces. Also make sure bed moves freely without much force except motor. If rods are not parallel you might need more force.
  • Homing is fine, all good there.
    Acceleration changes made no difference in the issue.
    This thing printed fine before so don't think the stepper current is an issue.
    I've lowered the jerk to 0 and no change. It's not mechanical issue because the first few layers print good. It bangs the stepper hard when it starts the letter detail on the cube.
    I've given up on getting auto level to work, I'm just trying to get it back to where it was before the update.
  • There is always a minimum jerk depending on acceleration. This is required for numerical stability, but that is normally no issue. Bang is not really what you should hear. You always have 90° corners and speed wise I expect more or less the same at each of it.
    When you can isolate the layer and run that in dry run and hear the bang I could test same layer as well, also I guess I'd not hear anything. But I've seen that very small moves can allow a faster direction change without deceleration, so maybe you have one of these cases here. Limits are per line switch so 5 20° changes on 0.1mm would make it move fast through that circle if you understand what I mean.
  • I did dry run and at layer 16 the issue starts,  it starts right at the letter detail on the cube.
    I also isolated each axis by removing belts an doing dry runs. It does this banging on both X and Y.
    I also ran the same g code on my other printer and it runs flawless. The issue has to be in the firmware.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 39
    #include "pins.h"
    #define HOST_RESCUE 1
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 400
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 85
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_MAX_ACCELERATION 3000
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 25
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 1
    #define RETRACTION_LENGTH 4
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0.15
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define TEMP_GAIN 0
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_Z_BACK_ON_HOME 1
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 1
    #define DISABLE_Y 1
    #define DISABLE_Z 0
    #define DISABLE_E 1
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define INVERT_X_DIR 1
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 260
    #define Y_MAX_LENGTH 225
    #define Z_MAX_LENGTH 180
    #define X_MIN_POS -40
    #define Y_MIN_POS -5
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 230
    #define DISTORTION_YMAX 205
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 16
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 4
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_PRE_RAISE_DISTANCE 5
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define ENABLE_BACKLASH_COMPENSATION 1
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define DOUBLE_STEP_DELAY 5 // time in microseconds
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 800
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 800
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 0
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 1
    #define Z_PROBE_BED_DISTANCE 2
    #define Z_PROBE_PIN ORIG_Z_MAX_PIN
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 35
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 0
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 70
    #define Z_PROBE_Y1 70
    #define Z_PROBE_X2 250
    #define Z_PROBE_Y2 70
    #define Z_PROBE_X3 70
    #define Z_PROBE_Y3 250
    #define BED_LEVELING_METHOD 0
    #define BED_LEVELING_GRID_SIZE 3
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 24
    #define ADC_KEYPAD_PIN 10
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define LANGUAGE_RU_ACTIVE 0
    #define UI_PRINTER_NAME "AFINIBOT2"
    #define UI_PRINTER_COMPANY "AFINIBOT"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define NUM_MOTOR_DRIVERS 0
  • Since firmware is responsible to limit speeds it is surely the reason, but question is which situation causes the problem so we know what the error is.
    You can try
    #define ALTERNATIVE_JERK
    #define REDUCE_ON_SMALL_SEGMENTS
    which uses alternative solution I had written to solve a similar thing.
  •  I added it here-
    This made no change and the problem still exists.
  • #define ENABLE_BACKLASH_COMPENSATION 0
    is better. With 1 you add extra moves which is a bad idea anyway. That might also cause the problem.
  • Any other ideas to try?
  • Not really. Only if you can isolate the problem to a move combination causing it it might be possible.
