Print randomly pausing at retract
I just built my first corexy and it prints pretty good.  I did not notice anything at first, but when I decided to do a torture test print I saw it randomly pause.  I thought maybe a bad USB cable or the buffer was running out because it always happened where it makes a lot of fast direction changes and stuff.  I swapped USB and watched the buffer and neither were the issue.  I did the exact same print on my AM8 with the exact same speeds, retract settings, board, drivers, steppers, extruder etc and it did just fine.
So I noticed that it was only doing this when it retracts and not every retract.  It will be fine for a minute then try to retract and the stepper goes really slow, and I'm talking barely moving slow sometimes.  It's not the same speed retract every time or I would think slicer settings.  Sometimes it's about 5 mm/s and others it's not even noticeable that it is moving unless you stand there staring at it for a while but then it retracts fine the next several times before retracting unbelievably slow ruining my print.  When it finally gets done with my 6 mm retract it will start moving at 100% again until another retract that makes it slow down.  I can run the same gcode again and it does this in different places each time.
I've swapped Arduinos, TMC driver, stepper, USB cable, tried a different stl and even printed with no extruder stepper plugged in.  Nothing changes.  The only difference between this one and my AM8 is this is corexy and my AM8 is not.
My setup:
Arduino Mega 2560 with RAMPS 1.6 and RAMPSXB
2 amp steppers with TMC 2130 drivers set to 1.5 amp (all fan cooled)
350W power supply
Hypercube corexy frame and gantry
Belt driven extruder for more torque
Repetier 1.0.3
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   This file is optimized for version 1.0.3
   as you expect.
#define NUM_EXTRUDER 5
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 1
#define XAXIS_STEPS_PER_MM 200
#define YAXIS_STEPS_PER_MM 200
#define ZAXIS_STEPS_PER_MM 400
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define SHARED_EXTRUDER_HEATER 1
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 544
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_PGAIN_OR_DEAD_TIME 34.7
#define EXT0_PID_I 4.11
#define EXT0_PID_D 73.21
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 370
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT1_HEATER_PIN HEATER_0_PIN
#define EXT1_INVERSE 1
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_PREHEAT_TEMP 190
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define EXT2_X_OFFSET 0
#define EXT2_Y_OFFSET 0
#define EXT2_Z_OFFSET 0
#define EXT2_STEPS_PER_MM 370
#define EXT2_TEMPSENSOR_TYPE 1
#define EXT2_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT2_HEATER_PIN HEATER_0_PIN
#define EXT2_STEP_PIN ORIG_E2_STEP_PIN
#define EXT2_DIR_PIN ORIG_E2_DIR_PIN
#define EXT2_INVERSE 1
#define EXT2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define EXT2_ENABLE_ON 0
#define EXT2_MIRROR_STEPPER 0
#define EXT2_STEP2_PIN ORIG_E2_STEP_PIN
#define EXT2_DIR2_PIN ORIG_E2_DIR_PIN
#define EXT2_INVERSE2 0
#define EXT2_ENABLE2_PIN ORIG_E2_ENABLE_PIN
#define EXT2_MAX_FEEDRATE 50
#define EXT2_MAX_START_FEEDRATE 20
#define EXT2_MAX_ACCELERATION 5000
#define EXT2_HEAT_MANAGER 3
#define EXT2_PREHEAT_TEMP 190
#define EXT2_WATCHPERIOD 1
#define EXT2_PID_INTEGRAL_DRIVE_MAX 230
#define EXT2_PID_INTEGRAL_DRIVE_MIN 40
#define EXT2_PID_PGAIN_OR_DEAD_TIME 7
#define EXT2_PID_I 2
#define EXT2_PID_D 40
#define EXT2_PID_MAX 255
#define EXT2_ADVANCE_K 0
#define EXT2_ADVANCE_L 0
#define EXT2_ADVANCE_BACKLASH_STEPS 0
#define EXT2_WAIT_RETRACT_TEMP 150
#define EXT2_WAIT_RETRACT_UNITS 0
#define EXT2_SELECT_COMMANDS ""
#define EXT2_DESELECT_COMMANDS ""
#define EXT2_EXTRUDER_COOLER_PIN -1
#define EXT2_EXTRUDER_COOLER_SPEED 255
#define EXT2_DECOUPLE_TEST_PERIOD 12000
#define EXT2_JAM_PIN -1
#define EXT2_JAM_PULLUP 0
#define EXT3_X_OFFSET 0
#define EXT3_Y_OFFSET 0
#define EXT3_Z_OFFSET 0
#define EXT3_STEPS_PER_MM 370
#define EXT3_TEMPSENSOR_TYPE 1
#define EXT3_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT3_HEATER_PIN HEATER_0_PIN
#define EXT3_STEP_PIN ORIG_E3_STEP_PIN
#define EXT3_DIR_PIN ORIG_E3_DIR_PIN
#define EXT3_INVERSE 1
#define EXT3_ENABLE_PIN ORIG_E3_ENABLE_PIN
#define EXT3_ENABLE_ON 0
#define EXT3_MIRROR_STEPPER 0
#define EXT3_STEP2_PIN ORIG_E3_STEP_PIN
#define EXT3_DIR2_PIN ORIG_E3_DIR_PIN
#define EXT3_INVERSE2 0
#define EXT3_ENABLE2_PIN ORIG_E3_ENABLE_PIN
#define EXT3_MAX_FEEDRATE 50
#define EXT3_MAX_START_FEEDRATE 20
#define EXT3_MAX_ACCELERATION 5000
#define EXT3_HEAT_MANAGER 3
#define EXT3_PREHEAT_TEMP 190
#define EXT3_WATCHPERIOD 1
#define EXT3_PID_INTEGRAL_DRIVE_MAX 230
#define EXT3_PID_INTEGRAL_DRIVE_MIN 40
#define EXT3_PID_PGAIN_OR_DEAD_TIME 7
#define EXT3_PID_I 2
#define EXT3_PID_D 40
#define EXT3_PID_MAX 255
#define EXT3_ADVANCE_K 0
#define EXT3_ADVANCE_L 0
#define EXT3_ADVANCE_BACKLASH_STEPS 0
#define EXT3_WAIT_RETRACT_TEMP 150
#define EXT3_WAIT_RETRACT_UNITS 0
#define EXT3_SELECT_COMMANDS ""
#define EXT3_DESELECT_COMMANDS ""
#define EXT3_EXTRUDER_COOLER_PIN -1
#define EXT3_EXTRUDER_COOLER_SPEED 255
#define EXT3_DECOUPLE_TEST_PERIOD 12000
#define EXT3_JAM_PIN -1
#define EXT3_JAM_PULLUP 0
#define EXT4_X_OFFSET 0
#define EXT4_Y_OFFSET 0
#define EXT4_Z_OFFSET 0
#define EXT4_STEPS_PER_MM 370
#define EXT4_TEMPSENSOR_TYPE 1
#define EXT4_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT4_HEATER_PIN HEATER_0_PIN
#define EXT4_STEP_PIN ORIG_E4_STEP_PIN
#define EXT4_DIR_PIN ORIG_E4_DIR_PIN
#define EXT4_INVERSE 1
#define EXT4_ENABLE_PIN ORIG_E4_ENABLE_PIN
#define EXT4_ENABLE_ON 0
#define EXT4_MIRROR_STEPPER 0
#define EXT4_STEP2_PIN ORIG_E4_STEP_PIN
#define EXT4_DIR2_PIN ORIG_E4_DIR_PIN
#define EXT4_INVERSE2 0
#define EXT4_ENABLE2_PIN ORIG_E4_ENABLE_PIN
#define EXT4_MAX_FEEDRATE 50
#define EXT4_MAX_START_FEEDRATE 20
#define EXT4_MAX_ACCELERATION 5000
#define EXT4_HEAT_MANAGER 3
#define EXT4_PREHEAT_TEMP 190
#define EXT4_WATCHPERIOD 1
#define EXT4_PID_INTEGRAL_DRIVE_MAX 230
#define EXT4_PID_INTEGRAL_DRIVE_MIN 40
#define EXT4_PID_PGAIN_OR_DEAD_TIME 7
#define EXT4_PID_I 2
#define EXT4_PID_D 40
#define EXT4_PID_MAX 255
#define EXT4_ADVANCE_K 0
#define EXT4_ADVANCE_L 0
#define EXT4_ADVANCE_BACKLASH_STEPS 0
#define EXT4_WAIT_RETRACT_TEMP 150
#define EXT4_WAIT_RETRACT_UNITS 0
#define EXT4_SELECT_COMMANDS ""
#define EXT4_DESELECT_COMMANDS ""
#define EXT4_EXTRUDER_COOLER_PIN -1
#define EXT4_EXTRUDER_COOLER_SPEED 255
#define EXT4_DECOUPLE_TEST_PERIOD 12000
#define EXT4_JAM_PIN -1
#define EXT4_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 5
#define RETRACTION_LONG_LENGTH 8
#define RETRACTION_SPEED 10
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_SPEED 10
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_PREHEAT_TEMP 50
#define HEATED_BED_MAX_TEMP 100
#define SKIP_M190_IF_WITHIN 2
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   296.05
#define HEATED_BED_PID_IGAIN   16.89
#define HEATED_BED_PID_DGAIN 1297.53
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 250
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR 1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 260
#define Y_MAX_LENGTH 280
#define Z_MAX_LENGTH 280
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 10
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 150
#define MAX_FEEDRATE_Y 150
#define MAX_FEEDRATE_Z 8
#define HOMING_FEEDRATE_X 80
#define HOMING_FEEDRATE_Y 80
#define HOMING_FEEDRATE_Z 3
#define HOMING_ORDER HOME_ORDER_XYTZ
#define ZHOME_PRE_RAISE 2
#define ZHOME_PRE_RAISE_DISTANCE 5
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 5
#define ZHOME_X_POS 130
#define ZHOME_Y_POS 100
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 1
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 300
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 300
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 300
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
#define MAX_JERK 15
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define FEATURE_TWO_ZSTEPPER 1
#define Z2_STEP_PIN   ORIG_E5_STEP_PIN
#define Z2_DIR_PIN    ORIG_E5_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E5_ENABLE_PIN
#define Z4_STEP_PIN   ORIG_E3_STEP_PIN
#define Z4_DIR_PIN    ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 0
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
        #define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 1
#define Z_PROBE_DISABLE_HEATERS 1
#define Z_PROBE_BED_DISTANCE 0
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 31
#define Z_PROBE_Y_OFFSET -33
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 2
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 0.35
#define Z_PROBE_DELAY 100
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 0
#define Z_PROBE_X2 260
#define Z_PROBE_Y2 0
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 280
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 9
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "HEVO5"
#define UI_PRINTER_COMPANY "HyperCube"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_MIN_HEATED_BED_TEMP  40
#define UI_SET_MAX_HEATED_BED_TEMP 100
#define UI_SET_MIN_EXTRUDER_TEMP   150
#define UI_SET_MAX_EXTRUDER_TEMP   250
#define NUM_MOTOR_DRIVERS 0
  • Ok looks like it’s a limitation of my board.  I guess the calculations for a corexy is just too much for my 8 bit board.  Looking into a better board.
  • How did you test? Printing with 50% did work fine I guess?
    Yes, you are quite edgy with the high resolution but I did not expect it taking that much CPU. But if printing slower works fine it is in deed a cpu problem. Due boards are then best solution.
  • Yea I was looking at the 32 bit boards you support and it looks like I can use a Due and RAMPS-FD or RADDS.  I really wanted the Duet because of the pure awesomeness, but cannot use Repetier and I really don't want to change firmware since Repetier is the best one I've used.
    I was reading up on the RAMPS + Re-ARM.  Would I just use the standard RAMPS 1.4 setting or is there a DUE based board I would choose for that?
  • Re-Arm is not compatible. They do not use the due processor. It is more a smoothieware clone with Mega 2560 pinout.
    Use RADDS if you can. That is what I develop on. If you use RAMPS-FD make sure to get the latest version and not the one with inverted heaters.
  • I was reading about the bad RAMPS-FD on another thread.  RADDS looks like my best option, but I'm worried about expandability.  I've only seen a 2 driver expansion board and since I use 2 dirvers for z that leaves me with only 4 extruder drivers.  I could possibly use 1 driver for Z and up the current to 2 amps since I have massive driver coolers.  At full speed those drivers were still cool to the touch (almost cold) while normally they get quite hot even at 1.5 amp.
    I'll be doing a lot of reading up on RADDS.  Any helpful links you know of?  Can I use my RRDFGSC or what display can I use like the RRDFGSC?
  • Found the extension board with 3 stepper slots.  I'll figure out the display and get it ordered.
    Next I'll need to figure out SPI for the TMC drivers.
    As usual, you guys are awesome and I am glad I found you all.
  • There is a thread here where the author of the TMC extension describes how to tweak RADDS to support them. You need some extra cables for chip select I think it was.
