2 problems. need help
Hello
I'm pretty new in the 3d print. so I ask for help in 2 issues. I have a 3d delta Kossel printer printer, arduino mega 256 with ramps 1.4 and Repetier-Firmware 1.0.1
This is the firmware that is loaded in the printer https://www.dropbox.com/sh/zi4u0moyoiqvjj8/AABXth8qbaYgoyLoDIzniHINa?dl=0
1. While printing, if you give the filament change command, the printhead does not return to the original location, the print will go wrong. Pause / continue print command is ok.
2. I recently bought a BL-Touch in the idea of making bed-leveling easier. and here begins the more complicated part and I can not handle it.
Can somebody help me with the configuration.h modification?
The printer is going well, but I have encountered cases where I had to change the filament and broke the printed piece.
Thanks in advance for your help.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.3dev
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 100
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 230
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 4
    #define RETRACTION_LONG_LENGTH 10
    #define RETRACTION_SPEED 80
    #define RETRACTION_Z_LIFT 0.1
    #define FILAMENTCHANGE_Z_ADD  20
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_PREHEAT_TEMP 70
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SET_INTERVAL 1500
    #define HEATED_BED_HEAT_MANAGER 2
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 180
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_X_MAX_INVERTING true
    #define ENDSTOP_Y_MAX_INVERTING true
    #define ENDSTOP_Z_MAX_INVERTING true
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define ENDSTOP_X_BACK_ON_HOME 20
    #define ENDSTOP_Y_BACK_ON_HOME 20
    #define ENDSTOP_Z_BACK_ON_HOME 20
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 1
    #define INVERT_Y_DIR 1
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 300
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 310 // mm
    #define DELTA_ALPHA_A 210
    #define DELTA_ALPHA_B 330
    #define DELTA_ALPHA_C 90
    #define DELTA_MAX_RADIUS 200
    #define ROD_RADIUS 173
    #define PRINTER_RADIUS 130
    #define DELTA_HOME_ON_POWER 1
    #define STEP_COUNTER
    //#define SOFTWARE_LEVELING
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 200
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 40
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
    #define MAX_JERK 10
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_BED_DISTANCE 5
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET -15
    #define Z_PROBE_Y_OFFSET -35
    #define Z_PROBE_SPEED 10
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 15
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 10
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 -69.28
    #define Z_PROBE_Y1 -40
    #define Z_PROBE_X2 69.40
    #define Z_PROBE_Y2 -40
    #define Z_PROBE_X3 0
    #define Z_PROBE_Y3 80
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 3
    #define BED_LEVELING_REPETITIONS 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 2
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "KOSSEL"
    #define UI_PRINTER_COMPANY "FLSun v092 30nov18"
    #define UI_SPEEDDEPENDENT_POSITIONING 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 1
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_HEATED_BED_TEMP  50
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
  • Some changes you need are
    #define SERVO0_NEUTRAL_POS  1500
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_HEIGHT 1.2      ;<<<<this is the value you change to set the bed too nozzle gap when probe is triggered
    thank you. I will try tomorrow
