Firmware Upload not possible
Hello,
i am trying to upload my repetier firmware with the  windows server. ( Arduino Due with Radds 1.6 )
if i use the firmware and the bin File, noting happens. I am getting only the Message "Hochladen beendet".  With checked detailled output i get no messages.
I can connect to the printer and use it normally.
The firmware upload with IDE is normally working.
  • Due has to usb ports and it matters which one you use. Server uploader also has 2 options for this, so it must match. So my first guess is that you selected the wrong upload method. You can also enable verbose to get more informations.
