Problem with x,y, axis Printing squareness issue ?
Can anyone help me solve a rather odd problem I have, I have spent hours trying to work out what could cause my (Y) position to be printing slightly longer on the left side of the bed than it does on the right side of the bed. I have squared up the Z axis with a 'square' and checked alignment between the left and right of the bed but even if this was out it would not explain why my prints come out longer on the left side than the right by about 1mm so what I have done is print an exact square of X50xY50mm at 1mm height but their is a very slight twist or something going on here im baffled any idea's how to solve this ?
Printer details: Prusa I3, Home Built, using firmware 0.92.6
controller LCD: RepRapDiscount Smart Controller
www.bigtree-tech.com
It has a red pcb extention board to interface with the LCD cables then to the LCD
Rather than uploading a photo that wont help much I will try to do a roughe text based graphic to help.
  yyyyyyyyyyy
x|----------------|
x|----------------|
x|----------------|
x|----------------|
x|----------------|
x|----------------|
1mm            ^shorter 49mm -1mm
51mm
Michelle
«1
  • Firmware uses same steps per mm over complete x axis. So from the signals it sends left and right should not differ in size. Of course steps per mm can change size but without difference left to right.
    Have you validated the slicer generated gcode to have same distance for a square? Also does it move around in same direction rotation wise?
    I agree that it very starnge and also have no idea why this could happen.
  • edited October 2018
    I really am not very good at understanding Gcode would it help if I posted my gcode generated for the sliced square here ? it should not be a big file as I only printed about 2 layers to save plastic for the test print. Could the problem be caused by me having different x,y, max length ? my  x max length = 200, and my y max length = 197, let me know if you want me to post the Gcode here or on dropbox or somewhere ! Regarding the rotation I think my circler objects are also printed slightly more oval on the left side than the right so it effects all shapes I print which is what is annoying me as I cannot print perfect circles so obviously this poses a big problem when printing threaded screws and bolts I printed the puzzle box threaded thing off thingyverse it came out distorted but still works just looks weird.  I uploaded my Gcode to my own website as it seems dropbox is not free anymore http://www.book-stores.com/files/calibration-square.txt
    Michelle
  • I made 2 video's doing some measurements on the problem.
    x,y, axis measurements
    Part one
    part two
    Michelle
  • Measuring only the first layer can be a big error! If Z distance to bed differs left to right the first layer perimeter will be wider or more narrow depending on z distance. That does not really mean x changes over axis. Print a 20mm cube left and right and measure again near the top. Single perimeter prints deform too easy to measure at that height.
  • Thanks Repetier, but in this case I doubt it is the problem as only reason I did the calibration square was that taller prints were bigger on the left than the right. I know what your saying though think its referred to as elephants foot! I did take extra care to measure the distance with a sheet of paper if anything the left side is slightly larger gap due to a slight warp in the glass bed. I find the edges of the plate are always bigger gap between nossle and glass sheet than the centre.
    Michelle
  • No, elephant foots are a bit different. You get them when the bed is too hot, then the bottom flows a bit outwards when you print the next layer.
    What I mean is that perimeter thickness differs if z height to bed is different. I saw you measured the inner hole or outer diameter. Both include the perimeter thickness. So you should also measure if perimeter have same width on bed. That is the error I meant.
    OK I understand, well for the moment I am 3D printing some new brackets as I did find some tiny discrepancies in vertical alignment not that this is the cause of my problem but I want to remove any errors I can to better track down my problem see video on this. after I get the new parts fitted and re-true the printer we can take it from there.
    Michelle
  • simple suggestion:
    try to fix a pen or pencil to your hotend and draw a square. that´s much more precise
  • RAyWB said:
    simple suggestion:
    good idea Ray will try thx
    RAyWB said:
    simple suggestion:
    OK so after running the Pen drawing test it has shown some opposite alignment issues which means I have moved something that half corrected the problem but moved it to the other side, I am uploading the video now and will be LIVE while fitting new brackets.
    Video of the pen draw test is here might still be uploading:
    Michelle
  • I have the feeling the circles inner/outer perimeter cross each other.
    There is one effect that may be a problem and that is backlash. With that head does not directly move only after x has moved a bit. A last thing that also causes different sizes is a excentric pulley. See if on fast x moves you see that pulley stays at position and does not wobble. Also check if x belt has a good tension. Both might cause the problem.
    Thanks, well I have just upgraded my belts from 3.5mm to 6mm widths to keep in-line with modern standards my former pulleys were for 3.5mm MXL-15T so as my pulleys were not wide enough for the newer 6mm wide belts I ordered new one's from china but these have not arrived in the post yet so 3D printed some for temporary usage so they may well be excentric as you say !!!
    I think this could be part of the problem, so will hope these new pulleys arrive soon before November, meanwhile will just calibrate as best I can. :)
    The pen test did show some crossing lines yes ..... Not sure how to fix that ?
    Michelle
    well, i watched the livestream for a couple of minutes. seems the printers frame is quite weak at all.
    may be you try to get the frame more rigid.(looks like made from plywood so it should be easy makeable)
    for the pen test may be its better just to send some manual commands
    f.e. on a low feedrate
    G1 X0 Y0 F1000
    G1 X200 ( i don´t know your max numbers so i just guessed)
    G1 Y200
    G1 X0
    G1 Y0
    that should draw a perfect square
    G1 X0 Y0 F1000
    G1 Y200
    G1 X0
    G1 Y0
    Thanks so much Ray, well in fact when my friend sent me this printer in the mail all the way from the USA it took one hell of a beating and the frame was shattered I will post a video here of the damage it suffered, I basically used steel re-enforcing washers on the lower part of the frame and a new 10mm bolt to secure the back chassis so it is fairly rigid. The problem might be it is distorted as theirs some bend in the upper beam bar were the Prusa I3 logo is laser etched onto it.
    Taken In January 2018
    Full Extent of Damage Just after Christmas 2017
    Since that time I spent a lot of time and effort fixing the frame. I also riveted steel laminations to the base of the printer bed mounting square section so all this is solid now.
    I will try out your manual commands after this print is done for the new Z axis homing switch bracket and after I have eaten some food, so give me a few hours say 3 hours and will try the code you gave me. I have re-calibrated the squareness again!
    Michelle
    OOps... printer in fragments.... wouldn´t it be better to kick that frame and make a complete rebuild ?
    I have considered it yes but its cost, really im on a fixed income so money is tight at the moment, but I do have an engineering background so made some rather hefty strong repairs its just squaring it up really :)
    Its always an option however if it turns out thats the only solution.
    Basically this is the frame mine uses
    https://tinyurl.com/ycolu4ze
    Michelle
    I will be going live in a few minutes to try out the commandline square writing with a pen on 3DP
  • Did more measurements printing a 2.4mm tall square their better but still slightly out maybe I should not complain as its about 0.7mm I think on Y-Axis.
  • try to print a square in half size , same height.
    if error is half then , adjust the steps /mm
    I am considering making some drastic changes to my 3D printer as both Z axis threaded rods are driven by separate stepper motors and one motor is stronger than the other this causes a tilt on my Z / X axis which can effect prints being tilted also. Not sure if this is what is causing my problems But I am thinking of mounting one motor on the top frame and using 2 belts and 3 gears of same size to drive both threaded Z axis rods not sure if anyone has done this before ? but it would help prevent my Z axis going cock-eyed after every tall print. Don't know if theirs another solution to this, I swapped the motors around right to left and left to right to see if this made a difference and it did now the left side climbs faster than the right so another problem to fix. I think I need to eradicate all these mechanical problems really to limit offset errors in other area's. OR can the Z axis stepper motors be slowed down a bit to solve this ?
  • to slow down just reduce feedrate to see what happens.
    so f.e. simply send a couple of manual codes :
    G1  Z100 F200
    G1 Z10
    G1  Z100 F300
    G1 Z10
    G1  Z100 F400
    G1 Z10
    so you can see if it´s a general problem OR it´s speed related
  • Thanks Ray, so could I insert this into my G-code files for when ever I do a print ? Reason I ask is its not always noticeable on a short 10mm or 30mm tall print, mostly after printing something 100mm tall or subsequent prints, I know this might seem off topic with my former x,y, subject but it may be related to my other problems with x,y so if I can insert this into my custom g.code file then time will show if it helps thanks.
    I guess this might be a static test ?
    Michelle
    Usually you limit the maximum z-speed in firmware,
    you can edit the eeprom settings via repetier host eeprom editor.
    so what i suggest is to find the feedrate limit via the manual moves , reduce that value to 80% and set the
    eeprom corresponding to that just to have a safe operation.
    whats the values for  feedrate  and acceleration in eeprom?
    OK well I am just waiting for a gearbox set of gears to finish printing then I will try, I could go live to run these tests, we'll see in about 30 minutes :)And I have made some slight changes in my eeprom settings for the y-min which was out previously but don't know which line is for z ? don't want to upset the printer will look after its finishes.
    you can export the eeprom settings to a file, so no danger damaging something.
    values for Z are indicated ;-)
    OK in the file which is hard to read btw theres this portion:
    Max. Z-jerk</epr><epr pos="133" type="3" value="-12.000">
    I assume this is the line ?
    Or this one:
    Z-axis acceleration</epr><epr pos="63" type="3" value="800.000">
    Its hard to see all the lines are joined.
    do you use repetier host?
    there is an eeprom editor included where you clearly can see each setting.
    BTW z-axis acceleration seems too high , z-jerk should not be a negative value...
    with export file i just mentioned to save the data ;-)
    OK Ray thanks, I lmost forgot I have to go to a group cake party meeting in about 1 hour, so will run more tests after I been there in the meantime I tried the G1  Z100 F200 it made a lot of servo noise very grinding noises but works smooth on G1  Z100 F100
    I will reduce those settings and try without the minus value but as far as I know  z-jerk has always been that way.
    I will try and go live for a while.
    Will try and live feed the trouble shooting but have to be quick.
  • Yes Repetier host and server
