G33 + height map - Delta
edited August 2018 in Questions & Answers
Hello! =D
My 3d printer is a delta and It has Bltouch.
When I send G33, all the probes are 4,xx mm and not 0,xx mm or 1,xx mm, why?
12:00:16.608 : N322 G33*26
12:00:16.608 : Z correction disabled
12:00:17.206 : N323 M105*37
12:00:20.293 : N324 M105*34
12:00:20.937 : Z-probe:4.38 X:-50.00 Y:49.97
12:00:23.149 : Z-probe:4.30 X:-33.34 Y:49.97
12:00:23.368 : N325 M105*35
12:00:25.408 : Z-probe:4.28 X:-16.68 Y:49.97
12:00:26.444 : N326 M105*32
12:00:27.620 : Z-probe:4.21 X:-0.01 Y:49.97
12:00:29.515 : N327 M105*33
12:00:29.843 : Z-probe:4.13 X:16.65 Y:49.97
12:00:32.055 : Z-probe:4.10 X:33.31 Y:49.97
12:00:32.590 : N328 M105*46
12:00:34.239 : Z-probe:4.12 X:49.98 Y:49.97
12:00:35.666 : N329 M105*47
12:00:38.268 : Z-probe:4.13 X:-50.00 Y:33.31
12:00:38.737 : N330 M105*39
12:00:40.464 : Z-probe:4.10 X:-33.34 Y:33.31
12:00:41.812 : N331 M105*38
12:00:42.676 : Z-probe:4.13 X:-16.68 Y:33.31
12:00:44.857 : Z-probe:4.12 X:-0.01 Y:33.31
12:00:44.888 : N332 M105*37
12:00:47.037 : Z-probe:4.10 X:16.65 Y:33.31
12:00:47.959 : N333 M105*36
12:00:49.260 : Z-probe:4.08 X:33.31 Y:33.31
12:00:49.921 : N334 M205*32
12:00:51.035 : N335 M105*34
12:00:51.476 : Z-probe:4.06 X:49.98 Y:33.31
12:00:54.110 : N336 M105*33
12:00:55.587 : Z-probe:4.14 X:-50.00 Y:16.65
12:00:57.181 : N337 M105*32
12:00:57.764 : Z-probe:4.16 X:-33.34 Y:16.65
12:00:59.976 : Z-probe:4.14 X:-16.68 Y:16.65
12:01:00.257 : N338 M105*47
12:01:02.203 : Z-probe:4.15 X:-0.01 Y:16.65
12:01:03.332 : N339 M105*46
12:01:04.431 : Z-probe:4.14 X:16.65 Y:16.65
12:01:06.404 : N340 M105*32
12:01:06.674 : Z-probe:4.12 X:33.31 Y:16.65
12:01:08.885 : Z-probe:4.11 X:49.98 Y:16.65
12:01:12.934 : Z-probe:4.21 X:-50.00 Y:-0.01
12:01:15.142 : Z-probe:4.21 X:-33.34 Y:-0.01
12:01:17.322 : Z-probe:4.19 X:-16.68 Y:-0.01
12:01:19.518 : Z-probe:4.18 X:-0.01 Y:-0.01
12:01:21.746 : Z-probe:4.17 X:16.65 Y:-0.01
12:01:23.963 : Z-probe:4.15 X:33.31 Y:-0.01
12:01:26.144 : Z-probe:4.14 X:49.98 Y:-0.01
12:01:30.192 : Z-probe:4.28 X:-50.00 Y:-16.67
12:01:32.389 : Z-probe:4.27 X:-33.34 Y:-16.67
12:01:34.647 : Z-probe:4.25 X:-16.68 Y:-16.67
12:01:36.890 : Z-probe:4.23 X:-0.01 Y:-16.67
12:01:39.075 : Z-probe:4.21 X:16.65 Y:-16.67
12:01:41.267 : Z-probe:4.20 X:33.31 Y:-16.67
12:01:43.494 : Z-probe:4.20 X:49.98 Y:-16.67
12:01:47.605 : Z-probe:4.28 X:-50.00 Y:-33.34
12:01:49.829 : Z-probe:4.30 X:-33.34 Y:-33.34
12:01:52.087 : Z-probe:4.30 X:-16.68 Y:-33.34
12:01:54.303 : Z-probe:4.28 X:-0.01 Y:-33.34
12:01:56.531 : Z-probe:4.24 X:16.65 Y:-33.34
12:01:58.738 : Z-probe:4.25 X:33.31 Y:-33.34
12:02:00.934 : Z-probe:4.23 X:49.98 Y:-33.34
12:02:04.983 : Z-probe:4.32 X:-50.00 Y:-50.00
12:02:07.195 : Z-probe:4.33 X:-33.34 Y:-50.00
12:02:09.387 : Z-probe:4.35 X:-16.68 Y:-50.00
12:02:11.587 : Z-probe:4.31 X:-0.01 Y:-50.00
12:02:13.830 : Z-probe:4.30 X:16.65 Y:-50.00
12:02:16.058 : Z-probe:4.28 X:33.31 Y:-50.00
12:02:18.281 : Z-probe:4.27 X:49.98 Y:-50.00
12:02:19.961 : Info:Distortion correction matrix:
12:02:19.961 : -381, -368, -366, -353, -341, -336, -339
12:02:19.977 : -341, -336, -341, -339, -336, -333, -330
12:02:19.977 : -343, -346, -342, -344, -342, -339, -337
12:02:19.977 : -354, -354, -351, -348, -347, -344, -342
12:02:19.977 : -364, -364, -359, -357, -353, -352, -351
12:02:19.992 : -366, -369, -368, -364, -359, -359, -356
12:02:19.992 : -371, -374, -376, -369, -369, -366, -364
Then, when I measure the Height map, all the z measures are 10,xx mm, minus the first measure, that are 1,36mm(I think this is correct) (See below)
X:		-50,00	-33,33	-16,67	0,00	16,67	33,33	50,00
y: 50,00 9,90 9,82 9,82 9,87 9,91 9,93 9,99
y: 33,33 9,99 10,02 10,01 10,01 9,99 9,98 10,00
y: 16,67 10,00 10,00 9,99 10,00 10,00 10,00 10,01
y: 0,00 10,03 10,00 10,00 10,01 10,01 10,02 10,01
y: -16,67 10,00 10,00 10,02 10,01 10,01 10,02 10,03
y: -33,33 10,00 10,00 10,01 10,01 10,00 10,00 10,01
y: -50,00 1,36 10,00 10,00 10,00 9,99 10,00 10,01
My configs:
#define Z_PROBE_Z_OFFSET 0.45
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET -19
#define Z_PROBE_SPEED 30
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 15
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 2
#define Z_PROBE_MIN_TEMPERATURE 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -50
#define Z_PROBE_Y1 -50
#define Z_PROBE_X2 -50
#define Z_PROBE_Y2 50
#define Z_PROBE_X3 50
#define Z_PROBE_Y3 -50
#define BED_LEVELING_METHOD 1
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 0
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 0
#define BED_MOTOR_3_Y 0
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
The Distortion
#define DISTORTION_CORRECTION_POINTS 7
#define DISTORTION_CORRECTION_R 50
#define DISTORTION_XMIN -50
#define DISTORTION_YMIN -50
#define DISTORTION_XMAX 50
#define DISTORTION_YMAX 50
What i am doing wrong?  The z probe offset I don't know if it correct.
Thanks for all
  • I have not had a Delta for awhile, but I seem to recall....
    Lets say you try this in the center of your bed X0,Y0:
    If your Z=0 is correct with autolevel and distortion correction disabled and parameters cleared with the probe enabled, if you go from Z0 to Z10 using G1 Z10 then a G30 should return a Z10.0 if your probe height is correctly set. I'm pretty sure that was how I initially set it. Then when you do a G33 with autolevel and distortion enabled, the number should be around 0 (plus or minus a small number.) depending on amount of correction needed.
  • edited August 2018
    Thanks for your reply.
    I test and my z=0 is OK.
    I send g1 z10, then g30 (the zprobes was 6.26) and it return to z10 *editing: when I press +0.01 it move more than 0.01
    I don't understand what you said. Does that mean at Z=10 the probe read 6.26? Your  probe height is off by 3.74. If you are at Z=10 it should return Z=10. The probe will go back to the start height after the g30.
    Yes, It was z10, it reads 6.26mm.
    What I change?
    Z_probe_height or z_probe_bed_distance?
    If I send g1 Z10 and then g33, all the measures must be +-10mm?
    Thanks again!
    *edit Sorry for my bad English, is not my first language
  • First you know
    means you have a 0.45 mm coating you do not want to consider? That is used normally only if you have inductive z probe and different bed coatings so it is easier to adjust.
    The general result is good regarding flat but values in distortion matrix should swing around 0. See G33 L0 to see your correction. Don't know your z resolution but that seems a lot more. As a effect moving from 0 to 0.1 you do 10% correction of that error in addition to 0.1mm move. So that explains the bigger moves at low z.
    It is important to use G33 on a height leveled by G32 S2 WITHOUT you having z length corrected in between. If you need to correct z length to make homing and G1 Z0 make it go to right height that just means z probe height was wrong and you correct an error in the wrong place and G33 again adds that error.
    First you know
    No, I was thinking this is the Z probe offset, distance between the nozzle and bed when the bl touch trigger.
    Z resolution is my steps per mm? All axis are 160. 1/32-step
    What is the best routine for I do leveling for my delta?
    First endstops correction
    G28
    G32 s2
    Z length correction
    G33
    G1 z5
    Height map
    Is this correct?
    And what's the difference between Z_probe_height and z_probe_bed_distance?
    Hi, i upgrade the firmware to 1.0 and I have better results! =D
    First height map
    y: 50,00 5,12 4,98 4,98 4,94 4,93 4,93 5,04
    y: 33,33 4,93 4,90 4,91 4,91 4,89 4,89 4,90
    y: 16,67 4,92 4,91 4,89 4,90 4,90 4,90 4,92
    y: 0,00 4,93 4,94 4,93 4,90 4,91 4,91 4,93
    y: -16,67 4,95 4,95 4,94 4,93 4,91 4,93 4,94
    y: -33,33 4,94 4,94 4,96 4,93 4,91 4,92 4,94
    y: -50,00 4,94 4,95 4,97 4,93 4,92 4,94 4,96
    G33
    10:08:52.165 : Info:Distortion correction matrix:
    10:08:52.165 : -8, 6, 3, 9, 10, 13, -2
    10:08:52.170 : 10, 14, 14, 16, 18, 17, 16
    10:08:52.174 : 15, 12, 16, 14, 15, 14, 11
    10:08:52.174 : 9, 9, 14, 14, 12, 12, 11
    10:08:52.174 : 5, 7, 10, 14, 15, 11, 8
    10:08:52.181 : 8, 10, 8, 10, 15, 13, 10
    10:08:52.181 : 9, 8, 7, 11, 15, 13, 8
    Height map + corrections
    y: 50,00 5,06 5,03 4,99 5,01 4,99 4,99 5,04
    y: 33,33 4,99 4,99 5,00 5,02 5,01 4,99 5,00
    y: 16,67 5,01 4,98 4,99 4,99 4,99 4,99 4,98
    y: 0,00 4,99 4,99 5,01 4,99 4,98 4,98 4,99
    y: -16,67 4,98 4,99 5,00 5,00 4,99 4,99 4,99
    y: -33,33 4,99 5,01 5,00 5,00 4,99 5,00 5,00
    Only one difficult, set the offset, because  the nozzle touch the bed in z=0,3mm =/
    How can I set this?
    here all my config
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #define FAN_THERMO_THERMISTOR_TYPE 14
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 160
    #define YAXIS_STEPS_PER_MM 160
    #define ZAXIS_STEPS_PER_MM 160
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 192.70
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 240
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_PREHEAT_TEMP 50
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_X_MAX_INVERTING true
    #define ENDSTOP_Y_MAX_INVERTING true
    #define ENDSTOP_Z_MAX_INVERTING true
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define max_software_endstop_r false
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 10
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 80
    #define Y_MAX_LENGTH 80
    #define Z_MAX_LENGTH 467.55
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 217 // mm
    #define DELTA_ALPHA_A 210
    #define DELTA_ALPHA_B 330
    #define DELTA_ALPHA_C 90
    #define DELTA_MAX_RADIUS 140
    #define ROD_RADIUS 111.26
    #define PRINTER_RADIUS 70
    #define DELTA_HOME_ON_POWER 0
    #define STEP_COUNTER
    #define DELTA_X_ENDSTOP_OFFSET_STEPS 16
    #define DELTA_Y_ENDSTOP_OFFSET_STEPS 208
    #define DELTA_Z_ENDSTOP_OFFSET_STEPS 120
    //#define SOFTWARE_LEVELING
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 400
    #define MAX_FEEDRATE_Y 400
    #define MAX_FEEDRATE_Z 400
    #define HOMING_FEEDRATE_X 80
    #define HOMING_FEEDRATE_Y 80
    #define HOMING_FEEDRATE_Z 80
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define UI_BED_COATING 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_BED_DISTANCE 0.9
    #define Z_PROBE_SWITCHING_DISTANCE 5
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 0
    #define Z_PROBE_DELAY 0
    #define Z_PROBE_START_SCRIPT "m340 p0 s700"
    #define Z_PROBE_FINISHED_SCRIPT "m340 p0 s1500"
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Delta"
    #define UI_PRINTER_COMPANY "FTW"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
  • Looks much better, except Z_PROBE_HEIGHT should be 0.3. You can set it in eeprom. That is the distance nozzle - bed when z probe triggers and which you thought was Z_PROBE_Z_OFFSET.
    z probe bed distance is the height where to start measurements from and should be a low value with enough margin for bed rotation, z probe. So 10mm or 5mm is normally a good value here. It has no influence on the result.
    And remember no length correction between G32 S2 and G33 - that is what you should change Z_PROBE_HEIGHT and retest starting with G32.
