Relative/Absolute setting for extrude distance?
Today I noticed my one printer of mine was only being sent repeating extrude commands  from the manual server interface.
Kept sending  G1 E14 F150, and it never incremented the E value as the button was pressed. Almost seemed as if it assumed the printer was expecting relative extrusion distances.
I restarted the server with no change.
I couldn't find a setting anywhere to alter this to the usual behavior. I eventually reinstalled the server and it worked normally again. This was after upgrading to 0.90.4
Is there a setting I missed somewhere? Is there a better way to fix this in the future?
~Andrew
  • The server analyses the communication and therefore knows what mode extruder is in, assuming absolute mode at startup. I have to check, but a explicit command to set absolute extrusion that gets send on connect might help.
