DIOORIG_FAN2_PIN_WPORT' was not declared in this scope
So I was redoing a configuration file on the firmware config tool and got this...
Question one: What is this for?
Question two: how do I fix this?
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch/HAL.h:83:0,
                 from sketch/Repetier.h:539,
                 from sketch/HAL.cpp:1:
sketch/HAL.cpp: In function 'void __vector_22()':
fastio.h:29: error: 'DIOORIG_FAN2_PIN_WPORT' was not declared in this scope
 #define  _WRITE(IO, v)   do { if (v) {DIO ##  IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ##  IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
sketch/fastio.h:48:25: note: in expansion of macro '_WRITE'
 #define  WRITE(IO, v)   _WRITE(IO, v)
sketch/HAL.cpp:847:91: note: in expansion of macro 'WRITE'
         if((pwm_pos_set[PWM_BOARD_FAN] = (pwm_pos[PWM_BOARD_FAN] & COOLER_PWM_MASK)) > 0) WRITE(FAN_BOARD_PIN,1);
fastio.h:29: error: 'DIOORIG_FAN2_PIN_PIN' was not declared in this scope
sketch/fastio.h:17:30: note: in definition of macro 'MASK'
  #define  MASK(PIN)    (1 << PIN)
sketch/HAL.cpp:947:108: note: in expansion of macro 'WRITE'
     if(pwm_pos_set[PWM_BOARD_FAN] == pwm_count_cooler && pwm_pos_set[NUM_EXTRUDER + 1] != COOLER_PWM_MASK) WRITE(FAN_BOARD_PIN,0);
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
  • fastio.h:29: error: 'DIOORIG_FAN2_PIN_WPORT' was not declared in this scope
    means you used a define ORIG_FAN2_PIN which is not defined. Here it looks like you enabled second extruder which uses by default FAN2_PIN but your board has not defined this. Select a pin number tha exists and where the pin is connected to or disable fan 2.
