sonam_18
Do we need to upload a start gcode and end gcode for the printer when it is newly built??
And do we have to set different gcode for different model ???
  • Only if the default does match your wishes. Slic3r will then add a simpel defaultthat is not optimized.
  • Hmmm thank you so much for the help...well i was trying to calibrate my machine and then trying for the bed leveling and suddenly the x axis stopped in the mid point and it wont move
    help please
  • In such cases always use the console/log to see what is going on.
    Often fimrware tells you about a problem,
  • what is the best temperature set for both the extruder and bed fort he first layer
  • Depends on bed coating and filament. The shown values will work for some pla filaments.
