Can this programme control the feeding speed and retract speed?
Hello ! I am new with this programme. I want to know how can I control the feeding rate or retracting rate by my own?
I really mean to increase or slow- down the motor speed for the motor that is used for the feeder.
(sorry if my English is not good)
  • Feeding rate is coupled to the move as it requires a set amount per mm computed by the slicer. Retraction speed is set in slicer but also fimrware might limit the speed. So you need to reconfigure the slicer configuration to change these for a print,
