Z offset
Raspberry Pi 3 and 7" display,
How can i change the Z Offset value from the display, and can i create a button on the screen for this feature??
  • If you mean step size, click on the distance button to change that setting.
  • i’m using marlin and enabling the auto bed leveling, so there is a feature called z offset to adjust the gap between the nozzel and the bed,
    This factor need sometimes to be changed due to many mechanical reasons, so it should be accessable
  • In console you can send any command. For frequently used commands you can add them in printer configuration->gcodes. Then you can call them from a dropdown list in console/manual control directly.
