Z Probe with BL Touch Error
I am trying to set BL Touch on my Delta printer, but without success.
My Settings:
#define FEATURE_SERVO 1
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define UI_SERVO_CONTROL 0
        #define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PIN Z_MIN_PIN
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 20.1
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
The error.
Repetier.h:1011: error: #endif without #if
 #endif
exit status 1
#error You need to define Z_PROBE_PIN to use z probe!
  • I see a couple error in the z probing section of the config
    #define Z_PROBE_PIN Z_MIN_PIN      should be   #define Z_PROBE_PIN ORIG_Z_MIN_PIN
    #define Z_PROBE_SWITCHING_DISTANCE 1    i would make this distance 5  to give enough room for probe to re deploy between probing
    #define Z_PROBE_HEIGHT 40     this value is the distance between bed and nozzle when the probe is triggered, 40 is way too high more realistically it will be between 1-2
