Click on filament segment to jump to and highlight related gcode
In Preview, it can be useful to see the gcode for a particular area or segment.  This is possible by scrolling through the code, but it is tedious.
Much easier would be a click (or double click) on a filament in the 3d display, and then gcode window then scrolls and highlights appropriately.
  • Yes, but that will unfortunately not work with our system. But you can at least jump to a layer directly at the bottom selecting layer and hit the button. Then you can mark code parts and also see where it is. Not as easy, but best I could do.
