Laser mode E increasing
Hello,
I use repetier firmware and I wonna select laser mode.
When I write in gcode M452 and M3 S255 then laser mode is selected and laser will turn on each line begins with G1 en laser turn of with G0. That works fine, but slic3r only use G1 commands and laser will not turn of on the right places.
In the firmware there is something writed about powdersystem that uses an increasing E value from extruder to turn on laser, but how you can use it? please help.
Greetz
  • In that case just enable laser mode M452 but do NOT enable it with M3 S255. Then when gcode contains an increasing E that move will be done with laser enabled, otherwise not.
  • it will not work,when i only write M452 in gcode program laser is off the whole time.When i write this:
    ; generated by Slic3r 1.2.9 on 2018-06-11 at 11:38:36
    ; external perimeters extrusion width = 0.40mm
    ; perimeters extrusion width = 0.48mm
    ; infill extrusion width = 0.48mm
    ; solid infill extrusion width = 0.48mm
    ; top infill extrusion width = 0.48mm
    M452
    M3
    G28 ; home all axes
    G1 Z5 F5000 ; lift nozzle
    G21 ; set units to millimeters
    G90 ; use absolute coordinates
    M82 ; use absolute distances for extrusion
    G92 E0
    G1 Z0.150 F7800.000
    G1 E-2.00000 F2400.00000
    G92 E0
    G1 Z0.650 F7800.000
    G1 X95.009 Y90.253 F7800.000
    G1 Z0.150 F7800.000
    G1 E2.00000 F2400.00000
    G1 X96.761 Y88.774 E2.20854 F1610.928
    G1 X98.913 Y87.981 E2.41708
    G1 X100.093 Y87.875 E2.52479
    G1 X124.907 Y87.875 E4.78111
    G1 X127.166 Y88.272 E4.98965
    G1 X129.154 Y89.415 E5.19819 F1610.928
    G1 X130.633 Y91.168 E5.40674
    G1 X131.426 Y93.320 E5.61528
    G1 X131.532 Y94.500 E5.72299
    G1 X131.532 Y99.500 E6.17764
    G1 X131.135 Y101.759 E6.38618
    G1 X129.991 Y103.747 E6.59472
    G1 X128.239 Y105.226 E6.80326
    G1 X126.087 Y106.019 E7.01180
    G1 X124.907 Y106.125 E7.11951
    G1 X100.093 Y106.125 E9.37583
    G1 X97.834 Y105.728 E9.58437
    G1 X95.846 Y104.585 E9.79291
    G1 X94.367 Y102.832 E10.00146
    G1 X93.574 Y100.680 E10.21000
    G1 X93.468 Y99.500 E10.31771
    G1 X93.468 Y94.500 E10.77236
    G1 X93.865 Y92.241 E10.98090
    G1 X94.979 Y90.305 E11.18398
    G1 E9.18398 F2400.00000
    G92 E0
    G1 Z0.650 F7800.000
    Then laser goes on and goes off by line starting with G92.
    I use the latest firmware version,here is config file:
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.3dev
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN -1
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 128
    #define YAXIS_STEPS_PER_MM 128
    #define ZAXIS_STEPS_PER_MM 5120
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 200
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_INTEGRAL_DRIVE_MAX 75
    #define EXT0_PID_INTEGRAL_DRIVE_MIN 20
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 75
    #define EXT0_PID_I 0.7
    #define EXT0_PID_D 800
    #define EXT0_PID_MAX 75
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_PREHEAT_TEMP 65
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 65
    #define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 20
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   75
    #define HEATED_BED_PID_IGAIN   0.7
    #define HEATED_BED_PID_DGAIN 800
    #define HEATED_BED_PID_MAX 65
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 1
    #define LASER_PIN HEATER_2_PIN
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 1
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN HEATER_2_PIN
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_Z_MAX_INVERTING true
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 1
    #define MOVE_Y_WHEN_HOMED 1
    #define MOVE_Z_WHEN_HOMED 1
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 280
    #define Y_MAX_LENGTH 194
    #define Z_MAX_LENGTH 145
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_PERMANENT 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 280
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 5
    #define HOMING_ORDER HOME_ORDER_YXZ
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 0
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 50
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 50
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 50
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 50
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 125
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 0
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 1
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #endif
  • In motion.cpp you see when it is turned on
    #if defined(SUPPORT_LASER) && SUPPORT_LASER
                else if(Printer::mode == PRINTER_MODE_LASER) {
                    p->secondSpeed = ((p->delta[X_AXIS] != 0 || p->delta[Y_AXIS] != 0) && (LaserDriver::laserOn || p->delta[E_AXIS] != 0) ? LaserDriver::intensity : 0);
                    p->delta[E_AXIS] = 0;
    #endif
    You see you need a x or y move and laserOn must be true or E value must be non zero.
    Your code still has M3 which sets laserOn true, you need to remove it as I said.
  • I have used the same gcode without M3 in it but then the laser would be off in the whole gcode program.that is just the thing I dont understand why the laser didn’t go on.
