Both Z axis steppers are moving the oposite direction
Hi guys,
I having a hard time problem solving, but I am getting there.
Just fixed my end stopping but;
When homing Z to Z min
Stepper Z1 and stepper Z2 are spinning towards each other, result is that the right side is going up and left is going down.
from the start it wanted to set Z home to the top so I inverted it:
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 180
What is going on and how is this fixable?
Thanks!
«1
  • just rotate the plug of one z- motor 180°
    does it matter which one?
  • turn the one which is spinning the wrong direction
    Thanks!
    That works now :)
    still got lots of issues, such as:
    - Nothing is heating; Decoupled error.
    - My max Y and max X endstops arent functioning for some reason.
    - when homing the X carriage is crashing on the left side.
    How to fix this stuff? there aren't any manuals or tutorials for this kind of stuff.
  • first of all some basics:
    front left  is xmin, ymin
    z-homing  shortest distance from bed to nozzle is z-min
    so - when homing the X carriage is crashing on the left side.
    homing direction is set to xmin....   max x endstop is useless for that
    if you tell us what kind of printer you build it is easier to help.
    I am modifying the Wanhao duplicator I3 prusa.
    I have put everything back as it was, except of the X carriage, which is replaced; but the endstop isn't.
    Will it also be usefull to post my configuration.h
    For reference in printer dimensions I used:
    The endstop for Z minus is working though, Only the Y-MAX and X-MAX aren't working.
    My config can be viewed here, to keep the post a little clean.
  • change these to 1 instead of -1
  • now X is going to the right and stops. Then Y is moving back and crashes to the back. Z minus is working properly. My endstops are connected to:
    X - max
    Y - max
    Z - min
  • edited May 2018
    so rotate connector of y motor, that should work
    edit:
    stop
    direction of movement is correct? just endstop doesn´t trigger
  • As the one I had to rotate for the Z motor ?
  • edited May 2018
    not shure at the moment, i edited previous answer
  • Yes. Directions are correct.
    Except of X which is moving to the right instead of original, but X is actually triggering now.
    So I have to rotate the endstop to let it trigger on X-min.
    The endstops aren't triggering.
    It's late where I life, so I can start modding after approx 4 hours of sleep and another 9 of work :neutral:
  • ok , same here ;-)
    i`m back at around 6PM CEST
  • Awesome! Go Europe! Thanks for all your help this far, really appriciate it :)
  • edited May 2018
    As there seem to be some more Problems we should see what we have actually...
    first of all place x-carriage and bed  each on halfway.
    what happens when you move x+ ? is it moving right or left ?
    what happens when you move y+ ? is it moving Forwards or backwards?
    you wrote z-homing to min is ok so i guess moving z+   makes movement upwards.
    with this Information we can start searching :-)
    btw, do you have a Display installed?
  • X is moving to the right
    Y is moving backwards
    Z is moving upwards
    Z homing is moving upwards, so I need to reverse that
    I also have my display installed.
  • With the Y endstop at the back of the bed, that is a Ymin endstop.
    So X0 Y0 puts the nozzle at the Front left corner of the bed
  • edited May 2018
    Right, i overlooked that last night.
    so connect the y endstop to y-min Input and reconfigure endstop
    also rotate x-motor and both z-Motor connectors by 180 degrees and
    Change the Settings to:
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR  1
    and do the following again so we can continue this evening
    what happens when you move x+ ? is it moving right or left ?  (should move right)
    what happens when you move y+ ? is it moving Forwards or backwards? (should move forwards)
    moving z+   makes movement upwards and homing should move downwards now.
    Aha, that's why the bed is crashing at the back.
    When rotating Z-motor connector, do I need to rotate both?
    So now:
    X-Home is moving right - endstop is working
    Z-Home is moving down - endstop not working
    Y-Home is moving back - endstop not working
    But doesn't my endstop Z minus has to be Z MAX because of swithing the Z motors?
  • edited May 2018
    ok, please post the complete configuration
    and what happens when moving x + , y+ , z+ ????
  • if possible please also a picture where you connected the enstops to radds board
  • X+ is moving Right
    Y+ is moving to Front (towards the  printer front)
    Z+ is moving Up
    My config:
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       generator: http://www.repetier.com/firmware/v092/
       as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 402
    #define RFSERIAL Serial
    #include "pins.h"
    #define FAN_BOARD_PIN -1
    // Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
    // If it is incompatible you will get compiler errors about write functions not beeing compatible!
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 640
    #define YAXIS_STEPS_PER_MM 640
    #define ZAXIS_STEPS_PER_MM 3200
    #define PDM_FOR_EXTRUDER 1
    #define PDM_FOR_COOLER 1
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    // ####################  EXTRUDER 0 ####################
    #define EXT0_X_OFFSET -18
    #define EXT0_Y_OFFSET -18
    #define EXT0_Z_OFFSET -18
    #define EXT0_STEPS_PER_MM 784
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_PIN E0_ENABLE_PIN
    #define EXT0_ENABLE_ON 1  //for RAPS128
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 5
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 240
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
    #define EXT0_DECOUPLE_TEST_PERIOD 30000
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 784
    #define EXT1_TEMPSENSOR_TYPE 8
    #define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
    #define EXT1_HEATER_PIN HEATER_0_PIN
    #define EXT1_STEP_PIN ORIG_E0_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E0_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN E0_ENABLE_PIN
    #define EXT1_ENABLE_ON 1  //for RAPS128
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_PGAIN_OR_DEAD_TIME 5
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 240
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
    #define EXT1_DECOUPLE_TEST_PERIOD 30000
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 1.9
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_X_POS 10
    #define FILAMENTCHANGE_Y_POS 10
    #define FILAMENTCHANGE_Z_ADD  10
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define RETRACT_DURING_HEATUP false
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define USE_GENERIC_THERMISTORTABLE_1
    #define GENERIC_THERM1_T0 25
    #define GENERIC_THERM1_R0 100000
    #define GENERIC_THERM1_BETA 3950
    #define GENERIC_THERM1_MIN_TEMP -20
    #define GENERIC_THERM1_MAX_TEMP 300
    #define GENERIC_THERM1_R1 0
    #define GENERIC_THERM1_R2 10000
    #define GENERIC_THERM_VREF 3.3
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_MAX_TEMP 100
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_PIN TEMP_2_PIN
    #define HEATED_BED_HEAT_MANAGER 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   7
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 280
    #define MIN_DEFECT_TEMPERATURE 5
    #define ENDSTOP_X_MAX_INVERTING true
    #define ENDSTOP_PULLUP_Y_MAX false
    #define ENDSTOP_PULLUP_Z_MAX false
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    // ##                           Movement settings                                          ##
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 900L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 20
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 10
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0  //?
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
    #define MAX_JERK 10
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define X2_ENABLE_PIN E1_ENABLE_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_ENABLE_PIN E1_ENABLE_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_ENABLE_PIN E1_ENABLE_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #define PS_ON_PIN -1
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 1
            #define FEATURE_WATCHDOG 0
    #define FEATURE_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 7
    #define UI_LANGUAGE 0
    #define UI_PRINTER_NAME "Duplicator I3"
    #define UI_PRINTER_COMPANY "James / Jetguy"
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 50
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_HEATED_BED_TEMP_ABS 90
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   220
    #define UI_SET_MAX_HEATED_BED_TEMP 110
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   240
    #define NUM_MOTOR_DRIVERS 0
    #endif
        "editMode": 2,
        "processor": 1,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 80,
        "yStepsPerMM": 80,
        "zStepsPerMM": 400,
        "xInvert": 0,
        "xInvertEnable": "1",
        "eepromMode": 1,
        "yInvert": 0,
        "yInvertEnable": "1",
        "zInvert": 0,
        "zInvertEnable": "1",
        "extruder": [
                "id": 0,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 240,
                "sensorType": 97,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "1",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 5,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 98,
                "coolerPin": "ORIG_FAN2_PIN",
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                    "enable": "E0_ENABLE_PIN"
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0"
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 1,
        "yMinEndstop": 1,
        "zMinEndstop": 1,
        "xMaxEndstop": 0,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "motherboard": 402,
        "driveSystem": 0,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 1000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 800,
        "yPrintAcceleration": 800,
        "zMaxSpeed": 20,
        "zHomingSpeed": 10,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 900,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 200,
        "yLength": 200,
        "zLength": 180,
        "alwaysCheckEndstops": "1",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "stepDoublerFrequency": 80000,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 10,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
            "enable": "E1_ENABLE_PIN"
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": 0,
        "mirrorZMotor": {
        "dittoPrinting": "0",
        "featureServos": "1",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "0",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_XYZ",
        "featureController": 7,
        "uiPrinterName": "Duplicator I3",
        "uiPrinterCompany": "James \/ Jetguy",
        "uiPagesDuration": 4000,
        "uiAnimation": "0",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "1",
        "uiPresetBedTempPLA": 50,
        "uiPresetBedABS": 90,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 220,
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 110,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 240,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 100,
        "bedSensorType": 97,
        "bedSensorPin": "TEMP_2_PIN",
        "bedHeatManager": 3,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 7,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 3950,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 10000,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 240,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "scalePidToMax": 0,
        "zProbePin": -1,
        "zProbeBedDistance": 10,
        "zProbePullup": "0",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 40,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 160,
        "zProbeY2": 20,
        "zProbeX3": 100,
        "zProbeY3": 160,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "sdSupport": "1",
        "sdCardDetectPin": "ORIG_SDCARDDETECT",
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "1",
        "pdmForCooler": "1",
        "psOn": -1,
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "sdRunOnStop": "",
        "featureRetraction": "0",
        "autoretractEnabled": "0",
        "retractionLength": 1.9,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 10,
        "filamentChangeYPos": 10,
        "filamentChangeZAdd": 10,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 1,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "primaryPort": 1,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertEnable": "0",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": true,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 92.3,
        "primaryPortName": "Serial"
  • as we see, movement directions are ok on all axis , and from looking at the config and also the x-endstop is working
    firmware setup seems ok.
    what about the wiring of endstops? is that ok?
    Doesn't the Z axis has to go down and X axis go left?
    Like:
  • Z-Axis : for homing to zmin it has to go down   when you move that  in + direction it has to go upwards
    X-Axis : for homing to xmax it has to go right .
    when you move it to - direction it has to move left , in + direction it has to move right
    Y-Axis for homing to y-min it has to move back
    moving in + direction it has to move forwards, moving in - direction it has to move backwards
    so as in your drawing if nozzle is on front left corner it is at 0,0,0
    moving to + direction means just to increase distance from nozzle to this point(0,0,0)
    how do you move  directions? ( i´m talking about repetier host manual control)
  • When homing to home all:
    X is right
    Z is top
    Y is back
    Y is correct according to the image.
    Z has to go down and X has to go left (at least according to the image and what it was in stock).
    Movement is easy regulated, the endstops aren't registering.
    That is a big issue.
    I can easily move my X enstop to the left side. But to avoid crashing iit has to work though.
    The thing I can't wrap my head around is that on stock it starts at 0,0,0 and stops at 20,20,18 (maximum build plate capacity) How can I set those dimensions accordingly?
  • before you wrote z is moving down... now you write z-is moving up....???????
    so you have to rotate both z motor connectors again ,
    lets do it step by step
    if you want to home x to the left side you have to move endstop to the left and set endstop xmin.
