Repetier Host: Manual control for 2nd fan
Hello,
Is it possible to manually control more than 1 fan in Repetier Host? If not, I'd welcome that function to be implemented.
  • You can select number of fans in printer settings->extruder. This adds Px to fan commands. Just make sure your firmware supports this. Repetier-Firmware 1.0.x supports 2 fans controlled that way. In version 2.x it will be unlimited number.
  • Thanks!
  • Do you have an idea when 2.0 will be released to the public?
  • Not really. I'm so busy that I can not make assumptions on date. It is already available on github in dev2 branch, but not everything is working and bigger things may change, so only usable if you know what you are doing and what is already working.
