Pin assignment changes
Hey guys
I have an MKS Base 1.5 board. Z min pin is not working. I used the web configuration to adding BUT how do.i manually assign a.pin in the pin.h file manually. I tried but disnt work.
Any pages I can visit to learn this?
  • No need for tricks. In config tool you can select any digital pin, not only one with assigned symbol name. So easy solution is to select the digital pin number of pin where you connected it.
