z axis motor spins clockwise fine but when it needs to spin anticlockwise it just spins clockwise
I have had the zonestar P802C since January and put it together no issues then I tested each motor and every motor connected to z axis port only spins in one direction no matter if it is set to go clockwise or anti clockwise it just goes clockwise starting to get annoyed please
  • That means the direction pin is not working. If you have a free motor socket use that instead. It is either a wrong pin number or a hardware defect, bus as I have no other reports about that I assume a hardware problem.
