PRO upgrade
Attempt to register upgrade license key fails with message "Invalid response from server".
  • Any help with this problem will be appreciated.
  • Did you buy a upgrade license instead of the full pro version? You can send us the license number if unsure and we can send you a link to buy the required OEM to convert it in a pro if that is the case. Please do not publish license here!
  • The license is described as "Repetier-Server Upgrade (OEM to Pro)"; so it would seem that your thoughts are probably correct. When I go into the Register screen it states that I'm on a Pro version trial; and can "upgrade at any time" !! so is this a different issue to the one you suggest?
  • Yes the triel just means you have no license but can use all pro features. You need a OEM license installed first than you can convert the cheaper OEM in a full pro. I send you the link in a PM.
  • edited January 2019
    Hello,
    I have exactly the same problem.
    I think I bought the wrong version (uprgade OEM to Pro).
    What can I do now?
  • Please check your messages her ein forum. I send you a solution.
  • wow this just happened to me too , i just spend $50 i actually couldn't afford
    does this mean i have to spend even more ?? jeezzz :( :(
  • i would really been ok with an oem license because all i wanted was the webcam feature , and i only need 1 installation on my raspberry pi
  • OEM is only for manufactors. But if you think you bought the wrong license please mail me the license and I can give you the same solution so you upgrade.
  • I have the Same Problem :(
  • Hello, i have an issue with licence upgrade. Same problem as arthur.
    Please help me to validate this.
  • SAME licence problem please help
  • I have the same problem. what can I do?
  • Please check your messages for solution.
  • edited November 2019
    @Repetier
     Can you please send to me also?
  • I have the same problem. Can you help me as well?
  • See you message box.
