LCD displays the question marks
Good afternoon.
This configuration: Repetier-Firmware V1.02 Mega 2560 + RAMPS1.4 + LCD12864 + SD. The coordinates x, y, z change every second to the question marks (?). What is wrong?
Thank you.
  • You did not home. Until you homed this indicates that real position is unknown and should not be trusted.
  • Thank you.
  • I see this too. But I homed the Z... lcd shows 0, but then when steppers are deactivated the ??? returns changeing from ??? to 0.00 this is normal?
  • you have to home ALL Axis, not only Z
  • When you disable motors position can change, so again position is untrusted.
