Stop print from LCD?
Hi all,
Does anyone know if it is possible to stop a print from the LCD when the print is being streamed from Repetier Server?
Sometimes I start a print from Server, but when I go to the printer I see that things are going wrong in a big way. Then I must run back to my PC, find the web page, then stop the print.
The SD Stop function does not work. Naturally... :)
Any other ideas?
Thank you,
Errol
  • If you have a reset button, you can use that. Server will see the reset and stop running job immediately. And it does not loose connection, so you can directly start next print.
  • I do have a reset button, but did not try that. Will try it next time. Thank you.
