Heater heat up but cannot reach to the temperature (2 to 5 degree below)
So I just install a e3d v6 into my Boxzy printer.
After I update the firmware and PID autotune it, I can still print PLA, but I notice the temperature was 2 degree below the temp I want. So I tried other filament that need a higher temp and the heater wont reach the temp (2 to 5 degree below) and the printer just don't start. For example, I print PETG at 250 degree but the heater only heat to 245-247 degree so the job will not start.
Now I can only print before preheat to 255 degree and start the job.
Does anyone know where is the problem ?
  • You see power does not get up as required. Typical reason is that drive max is still on 130/180in configuration limiting the I part of pid controller. Increase that value to what you need.
  • Thanks for answering . My drive max 255 already and still not getting to the temp
    here is my setting
  • edited January 2018
    looks like 24V heater powered with 12V only.
    can you measure heaters resistance?
    for 40 Watts:
    12V Heaters are around 3.6 Ohms
    24V Heaters are around 14.4 Ohms
    for 40 Watts:
    I don't have the equipment to measure but the heater has marked as 12V 30 watts. Ordered from E3D in a full kit
  • That looks wrong. You have set pwm max values to 255 but even when heating is low it seems you are only using 25% of the power. Is this correct? If you set heat manager to 0 does it also limit to 25% power? There it uses PID max value and that is according to eeprom 255.
    Is this the original firmware or some forked and modified version? If it was modified for 24V on 12V heaters it would explain it.
    So I guess i fix it now by increasing the value of PID drive min from 70 to 140. Work fine now ! Thanks for the help !!!!
  • drive min should not be the problem. Only the fact that you seem to not get over 25%. With high drive min you might get problems with lower tempertures. YOu now just force the high value also max is even higher and was no real limit.
    So I tried to use 0 in heat manager and the power go all the way up. The firmware is a custom one for Boxzy printer but I dont know if it is for 24v or 12v heaters
    So I was finally fix the heating problem by using an unofficial firmware made by another Boxzy user, a new problem occurred.
    The dead-time control now is really work and there is no limit to the power, but after few second of starting the print. It stop and got a error like this :
    00:39:04.617 : Error: value [0-255]
    00:39:04.617 : Resend:1974
    00:39:04.630 : Resend: N1974 M117 ETE 5m 30s*67
    00:39:04.630 : Resend: N1975 M105*29
    00:39:04.630 : Resend: N1976 G1 X71.6 Y95.9 E29.33454*96
    00:39:04.630 : Resend: N1977 G1 X71.6 Y69.1 E31.34013*99
    00:39:04.630 : Resend: N1978 G0 X71 Y68.5 F2820*98
    00:39:04.630 : Resend: N1979 G1 X94 Y68.5 E33.06134 F1080*19
    00:39:04.638 : Error: value [0-255]
    00:39:04.638 : Resend:1974
    00:39:07.655 : Warning: Seems like we missed a ok, got a wait - continue sending.
    00:39:07.655 : N1980 M105*23
    00:39:07.655 : N1981 M117 ETE 5m 25s*77
    00:39:07.655 : N1982 G1 X94 Y96.5 E35.15673*121
    00:39:07.656 : N1983 G1 X71 Y96.5 E36.87794*115
    00:39:07.656 : N1984 G1 X71 Y68.5 E38.97333*115
    00:39:07.656 : N1985 G1 E34.47333 F2400*1
    00:39:07.657 : N1986 G0 X72.8 Y70.3 F2820*121
    00:39:07.664 : Error:expected line 1974 got 1980
    00:39:07.664 : Resend:1974
    00:39:07.678 : Resend: N1974 M117 ETE 5m 30s*67
    00:39:07.678 : Resend: N1975 M105*29
    00:39:07.678 : Resend: N1976 G1 X71.6 Y95.9 E29.33454*96
    00:39:07.678 : Resend: N1977 G1 X71.6 Y69.1 E31.34013*99
    00:39:07.678 : Resend: N1978 G0 X71 Y68.5 F2820*98
    00:39:07.678 : Resend: N1979 G1 X94 Y68.5 E33.06134 F1080*19
    00:39:07.678 : Resend: N1980 M105*23
    00:39:07.684 : Error: value [0-255]
    00:39:07.684 : Resend:1974
    00:39:10.703 : Warning: Seems like we missed a ok, got a wait - continue sending.
    00:39:10.703 : Resend: N1981 M117 ETE 5m 25s*77
    00:39:10.703 : Resend: N1982 G1 X94 Y96.5 E35.15673*121
    00:39:10.703 : Resend: N1983 G1 X71 Y96.5 E36.87794*115
    00:39:10.703 : Resend: N1984 G1 X71 Y68.5 E38.97333*115
    00:39:10.703 : Resend: N1985 G1 E34.47333 F2400*1
    00:39:10.703 : Resend: N1986 G0 X72.8 Y70.3 F2820*121
    00:39:10.703 : N1987 M105*16
    00:39:10.712 : Error:expected line 1974 got 1981
    00:39:10.712 : Resend:1974
    00:39:10.726 : Resend: N1974 M117 ETE 5m 30s*67
    00:39:10.726 : Resend: N1975 M105*29
    00:39:10.726 : Resend: N1976 G1 X71.6 Y95.9 E29.33454*96
    00:39:10.726 : Resend: N1977 G1 X71.6 Y69.1 E31.34013*99
    00:39:10.726 : Resend: N1978 G0 X71 Y68.5 F2820*98
    00:39:10.726 : Resend: N1979 G1 X94 Y68.5 E33.06134 F1080*19
    00:39:10.726 : Resend: N1980 M105*23
    00:39:10.732 : Error: value [0-255]
    00:39:10.736 : Resend:1974
    00:39:13.754 : Warning: Seems like we missed a ok, got a wait - continue sending.
    00:39:13.754 : Resend: N1981 M117 ETE 5m 25s*77
    00:39:13.754 : Resend: N1982 G1 X94 Y96.5 E35.15673*121
    00:39:13.754 : Resend: N1983 G1 X71 Y96.5 E36.87794*115
    00:39:13.754 : Resend: N1984 G1 X71 Y68.5 E38.97333*115
    00:39:13.754 : Resend: N1985 G1 E34.47333 F2400*1
    00:39:13.754 : Resend: N1986 G0 X72.8 Y70.3 F2820*121
    00:39:13.754 : Resend: N1987 M105*16
    00:39:13.762 : Error:expected line 1974 got 1981
    00:39:13.762 : Resend:1974
    00:39:13.776 : Resend: N1974 M117 ETE 5m 30s*67
    00:39:13.776 : Resend: N1975 M105*29
    00:39:13.776 : Resend: N1976 G1 X71.6 Y95.9 E29.33454*96
    00:39:13.776 : Resend: N1977 G1 X71.6 Y69.1 E31.34013*99
    00:39:13.776 : Resend: N1978 G0 X71 Y68.5 F2820*98
    00:39:13.776 : Resend: N1979 G1 X94 Y68.5 E33.06134 F1080*19
    00:39:13.776 : Resend: N1980 M105*23
    00:39:13.783 : Error: value [0-255]
    00:39:13.783 : Resend:1974
    00:39:16.801 : Warning: Seems like we missed a ok, got a wait - continue sending.
    00:39:16.801 : Resend: N1981 M117 ETE 5m 25s*77
    00:39:16.802 : Resend: N1982 G1 X94 Y96.5 E35.15673*121
    00:39:16.802 : Resend: N1983 G1 X71 Y96.5 E36.87794*115
    00:39:16.802 : Resend: N1984 G1 X71 Y68.5 E38.97333*115
    00:39:16.802 : Resend: N1985 G1 E34.47333 F2400*1
    00:39:16.802 : Resend: N1986 G0 X72.8 Y70.3 F2820*121
    00:39:16.802 : Resend: N1987 M105*16
    00:39:16.810 : Error:expected line 1974 got 1981
    00:39:16.810 : Resend:1974
    00:39:16.824 : Resend: N1974 M117 ETE 5m 30s*67
    00:39:16.824 : Resend: N1975 M105*29
    00:39:16.824 : Resend: N1976 G1 X71.6 Y95.9 E29.33454*96
    00:39:16.824 : Resend: N1977 G1 X71.6 Y69.1 E31.34013*99
    00:39:16.824 : Resend: N1978 G0 X71 Y68.5 F2820*98
    00:39:16.824 : Resend: N1979 G1 X94 Y68.5 E33.06134 F1080*19
    00:39:16.824 : Resend: N1980 M105*23
    00:39:16.831 : Error: value [0-255]
    00:39:16.831 : Resend:1974
    00:39:19.848 : Warning: Seems like we missed a ok, got a wait - continue sending.
    00:39:19.848 : Resend: N1981 M117 ETE 5m 25s*77
    00:39:19.848 : Resend: N1982 G1 X94 Y96.5 E35.15673*121
    00:39:19.848 : Resend: N1983 G1 X71 Y96.5 E36.87794*115
    00:39:19.848 : Resend: N1984 G1 X71 Y68.5 E38.97333*115
    00:39:19.848 : Resend: N1985 G1 E34.47333 F2400*1
    00:39:19.848 : Resend: N1986 G0 X72.8 Y70.3 F2820*121
    00:39:19.848 : Resend: N1987 M105*16
    00:39:19.857 : Error:expected line 1974 got 1981
    00:39:19.857 : Resend:1974
    00:39:19.871 : Resend: N1974 M117 ETE 5m 30s*67
    00:39:19.871 : Resend: N1975 M105*29
    00:39:19.871 : Resend: N1976 G1 X71.6 Y95.9 E29.33454*96
    00:39:19.871 : Resend: N1977 G1 X71.6 Y69.1 E31.34013*99
    00:39:19.871 : Resend: N1978 G0 X71 Y68.5 F2820*98
    00:39:19.871 : Resend: N1979 G1 X94 Y68.5 E33.06134 F1080*19
    00:39:19.871 : Resend: N1980 M105*23
    00:39:19.878 : Error: value [0-255]
    00:39:19.878 : Resend:1974
    00:39:22.895 : Warning: Seems like we missed a ok, got a wait - continue sending.
    00:39:22.895 : Resend: N1981 M117 ETE 5m 25s*77
    00:39:22.895 : Resend: N1982 G1 X94 Y96.5 E35.15673*121
    00:39:22.895 : Resend: N1983 G1 X71 Y96.5 E36.87794*115
    00:39:22.895 : Resend: N1984 G1 X71 Y68.5 E38.97333*115
    00:39:22.895 : Resend: N1985 G1 E34.47333 F2400*1
    00:39:22.895 : Resend: N1986 G0 X72.8 Y70.3 F2820*121
    00:39:22.895 : Resend: N1987 M105*16
    00:39:22.904 : Error:expected line 1974 got 1981
    00:39:22.904 : Resend:1974
    00:39:22.918 : Resend: N1974 M117 ETE 5m 30s*67
    00:39:22.918 : Resend: N1975 M105*29
    00:39:22.918 : Resend: N1976 G1 X71.6 Y95.9 E29.33454*96
    00:39:22.918 : Resend: N1977 G1 X71.6 Y69.1 E31.34013*99
    00:39:22.918 : Resend: N1978 G0 X71 Y68.5 F2820*98
    00:39:22.918 : Resend: N1979 G1 X94 Y68.5 E33.06134 F1080*19
    00:39:22.918 : Resend: N1980 M105*23
    00:39:22.925 : Error: value [0-255]
    00:39:22.925 : Resend:1974
    So do you know what is happening ?
  • You only show 30% of communication. For analysis always use the real log to a file or at least activate all log parts.
    Also always start with the good part so we can see how bad part evolves.
    From the messages it seems like firmware is not sending all "ok" responses. Maybe related to the error message wanting a value 0-255 but gets always resend the same value. Never seen this error.
  • edited February 2018
    Sorry I am not really familiar with the log, so here is the log.
    < 12:52:57.928 : OpenGL version:4.0.0 - Build 9.18.10.3165
    < 12:52:57.929 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_EXT_texture_storage GL_ARB_texture_storage GL_INTEL_map_texture GL_ARB_ES2_compatibility
    < 12:52:57.929 : OpenGL renderer:Intel(R) HD Graphics 4400
    < 12:52:57.929 : Using fast VBOs for rendering is possible
    < 12:54:00.090 : Printer reset detected - initalizing
    > 12:54:00.092 : start
    > 12:54:00.103 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    > 12:54:00.103 : Free RAM:3191
    > 12:54:00.125 : SelectExtruder:0
    > 12:54:00.126 : FlowMultiply:100
    < 12:54:00.287 : CncPlugin: Change step size to 1 mm
    < 12:54:00.295 : N1 M110*34
    < 12:54:00.295 : N2 M115*36
    < 12:54:00.295 : N3 M105*36
    < 12:54:00.295 : N4 M114*35
    < 12:54:00.295 : N5 M111 S6*98
    < 12:54:00.298 : N6 T0*60
    < 12:54:00.299 : N7 M107*34
    < 12:54:00.299 : N8 M80*19
    > 12:54:00.303 : ok
    > 12:54:00.305 : ok 2
    < 12:54:00.325 : N9 M220 S100*104
    < 12:54:00.325 : N10 M221 S100*81
    < 12:54:00.325 : N11 M111 S6*87
    < 12:54:00.325 : N12 T0*9
    > 12:54:00.325 : FIRMWARE_NAME:BoXZY_Repetier_0.92.9 FIRMWARE_URL:https://github.com/dewhisna/Repetier-Firmware/tree/BoXZY_Custom PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    > 12:54:00.328 : Printed filament:21.23m Printing time:0 days 14 hours 38 min
    > 12:54:00.328 : PrinterMode:FFF
    > 12:54:00.328 : ok 3
    > 12:54:00.348 : T:78.74 /0 @:0
    > 12:54:00.348 : ok 4
    > 12:54:00.348 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    > 12:54:00.348 : ok 5
    > 12:54:00.348 : DebugLevel:6
    > 12:54:00.348 : ok 6
    > 12:54:00.348 : SelectExtruder:0
    > 12:54:00.349 : FlowMultiply:100
    > 12:54:00.349 : ok 7
    > 12:54:00.349 : ok 8
    > 12:54:00.349 : ok 9
    > 12:54:00.349 : SpeedMultiply:100
    > 12:54:00.349 : ok 10
    > 12:54:00.349 : ok 11
    > 12:54:00.349 : DebugLevel:6
    > 12:54:00.349 : ok 12
    > 12:54:00.350 : SelectExtruder:0
    > 12:54:00.350 : FlowMultiply:100
    > 12:54:00.705 : BoXZY 3D Printer Head detected
    > 12:54:01.339 : wait
    > 12:54:02.343 : wait
    < 12:54:03.332 : N13 M105*21
    > 12:54:03.334 : ok 13
    > 12:54:03.340 : T:77.90 /0 @:0
    > 12:54:04.338 : wait
    > 12:54:05.337 : wait
    > 12:54:06.340 : wait
    < 12:54:06.393 : N14 M105*18
    > 12:54:06.398 : ok 14
    > 12:54:06.400 : T:77.10 /0 @:0
    < 12:54:06.718 : Starting object analyser ...
    < 12:54:06.725 : Object is manifold.
    < 12:54:06.727 : Analysing finished.
    > 12:54:07.397 : wait
    > 12:54:08.397 : wait
    > 12:54:09.400 : wait
    < 12:54:09.455 : N15 M105*19
    > 12:54:09.458 : ok 15
    > 12:54:09.458 : T:76.29 /0 @:0
    < 12:54:09.893 : CuraEngine command:D:\Repetier-Host\plugins\CuraEngine\CuraEngine.exe -p -v -c "C:\Users\YT Piko\AppData\Local\RepetierHost\cura.ini" -s posx=0 -s posy=0 -o "C:\Users\YT Piko\AppData\Local\RepetierHost\composition.gcode" "C:\Users\YT Piko\AppData\Local\RepetierHost\composition0.stl"
    < 12:54:09.898 : Preferred name from test to test
    < 12:54:09.929 : <CuraEngine> Cura_SteamEngine version 15.01
    < 12:54:09.929 : <CuraEngine> Copyright (C) 2014 David Braam
    < 12:54:09.929 : <CuraEngine> This program is free software: you can redistribute it and/or modify
    < 12:54:09.929 : <CuraEngine> it under the terms of the GNU Affero General Public License as published by
    < 12:54:09.929 : <CuraEngine> the Free Software Foundation, either version 3 of the License, or
    < 12:54:09.929 : <CuraEngine> (at your option) any later version.
    < 12:54:09.929 : <CuraEngine> This program is distributed in the hope that it will be useful,
    < 12:54:09.929 : <CuraEngine> but WITHOUT ANY WARRANTY; without even the implied warranty of
    < 12:54:09.929 : <CuraEngine> MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    < 12:54:09.929 : <CuraEngine> GNU Affero General Public License for more details.
    < 12:54:09.929 : <CuraEngine> You should have received a copy of the GNU Affero General Public License
    < 12:54:09.929 : <CuraEngine> along with this program.  If not, see <http://www.gnu.org/licenses/>.
    < 12:54:09.929 : <CuraEngine> Default config 'default.cfg' not used
    < 12:54:09.929 : <CuraEngine> Loading C:\Users\YT Piko\AppData\Local\RepetierHost\composition0.stl from disk...
    < 12:54:09.929 : <CuraEngine> Loaded from disk in 0.000s
    < 12:54:09.929 : <CuraEngine> Analyzing and optimizing model...
    < 12:54:09.929 : <CuraEngine>   Face counts: 32 -> 32 100.0%
    < 12:54:09.929 : <CuraEngine>   Vertex counts: 96 -> 16 16.7%
    < 12:54:09.929 : <CuraEngine>   Size: 20.000000 25.000000 10.000000
    < 12:54:09.929 : <CuraEngine>   vMin: 72.500000 70.000000 0.000000
    < 12:54:09.929 : <CuraEngine>   vMax: 92.500000 95.000000 10.000000
    < 12:54:09.929 : <CuraEngine>   Matrix: 1.000000 0.000000 0.000000
    < 12:54:09.929 : <CuraEngine>   Matrix: 0.000000 1.000000 0.000000
    < 12:54:09.929 : <CuraEngine>   Matrix: 0.000000 0.000000 1.000000
    < 12:54:09.929 : <CuraEngine> Optimize model 0.000s
    < 12:54:09.929 : <CuraEngine> Slicing model...
    < 12:54:09.929 : <CuraEngine> Layer count: 50
    < 12:54:09.930 : <CuraEngine> Sliced model in 0.000s
    < 12:54:09.930 : <CuraEngine> Generating support map...
    < 12:54:09.931 : <CuraEngine> Generating layer parts...
    < 12:54:09.933 : <CuraEngine> Generated layer parts in 0.000s
    < 12:54:09.944 : <CuraEngine> Generated inset in 0.000s
    < 12:54:09.957 : <CuraEngine> Generated up/down skin in 0.016s
    < 12:54:10.029 : <CuraEngine> Wrote layers in  0.08s.
    < 12:54:10.029 : <CuraEngine> Wrote  93.2 kilobytes.
    < 12:54:10.029 : <CuraEngine> Total time elapsed  0.09s.
    < 12:54:10.029 : <CuraEngine> Print time: 360
    < 12:54:10.029 : <CuraEngine> Filament: 339
    < 12:54:10.029 : <CuraEngine> Filament2: 0
    > 12:54:10.457 : wait
    > 12:54:11.460 : wait
    < 12:54:11.674 : N16 G28*36
    < 12:54:11.674 : N17 M117 ETE 5m 58s*64
    < 12:54:11.678 : N18 G1 Z15 F300*58
    < 12:54:11.679 : N19 M107*29
    < 12:54:11.679 : N20 G90*34
    < 12:54:11.679 : N21 M82*42
    < 12:54:11.680 : N22 M104 T0 S240*23
    < 12:54:11.680 : N23 G92 E0*118
    < 12:54:11.680 : N24 M109 T0 S240*28
    < 12:54:11.681 : N25 M107*18
    > 12:54:11.686 : ok 16
    < 12:54:11.686 : N26 G0 X74.8 Y72.3 Z0.3 F2820*40
    > 12:54:13.685 : busy:processing
    > 12:54:15.683 : busy:processing
    > 12:54:17.686 : busy:processing
    > 12:54:19.684 : busy:processing
    > 12:54:21.683 : busy:processing
    > 12:54:22.252 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    > 12:54:22.252 : ok 17
    > 12:54:22.253 : ok 18
    < 12:54:22.253 : N27 M105*18
    < 12:54:22.253 : N28 M117 ETE 5m 52s*70
    > 12:54:22.253 : ok 19
    > 12:54:22.253 : ok 20
    < 12:54:22.253 : Printing layer 1 of 50
    < 12:54:22.253 : N29 G1 X74.8 Y92.699 E1.52657 F1080*50
    > 12:54:22.257 : ok 21
    > 12:54:22.257 : ok 22
    > 12:54:22.257 : TargetExtr0:240
    > 12:54:22.257 : ok 23
    < 12:54:22.257 : N30 M117 ETE 5m 51s*76
    > 12:54:22.257 : ok 24
    < 12:54:22.257 : N31 G1 X90.199 Y92.699 E2.67895*82
    > 12:54:24.255 : busy:processing
    > 12:54:25.426 : TargetExtr0:240
    > 12:54:26.254 : busy:heating
    > 12:54:26.426 : T:74.51 /240 @:255
    > 12:54:27.430 : T:76.64 /240 @:255
    > 12:54:28.256 : busy:heating
    > 12:54:28.430 : T:79.48 /240 @:255
    > 12:54:29.432 : T:82.66 /240 @:255
    > 12:54:30.255 : busy:heating
    > 12:54:30.432 : T:86.15 /240 @:255
    > 12:54:31.431 : T:89.97 /240 @:255
    > 12:54:32.258 : busy:heating
    > 12:54:32.435 : T:93.84 /240 @:255
    > 12:54:33.434 : T:97.77 /240 @:255
    > 12:54:34.257 : busy:heating
    > 12:54:34.438 : T:101.75 /240 @:255
    > 12:54:35.437 : T:105.80 /240 @:255
    > 12:54:36.256 : busy:heating
    > 12:54:36.441 : T:109.71 /240 @:255
    > 12:54:37.441 : T:113.78 /240 @:255
    > 12:54:38.259 : busy:heating
    > 12:54:38.439 : T:117.69 /240 @:255
    > 12:54:39.442 : T:121.59 /240 @:255
    > 12:54:40.257 : busy:heating
    > 12:54:40.442 : T:125.91 /240 @:255
    > 12:54:41.441 : T:129.62 /240 @:255
    > 12:54:42.256 : busy:heating
    > 12:54:42.447 : T:133.61 /240 @:255
    > 12:54:43.444 : T:137.39 /240 @:255
    > 12:54:44.259 : busy:heating
    > 12:54:44.447 : T:141.07 /240 @:255
    > 12:54:45.447 : T:144.95 /240 @:255
    > 12:54:46.258 : busy:heating
    > 12:54:46.450 : T:148.47 /240 @:255
    > 12:54:47.451 : T:151.78 /240 @:255
    > 12:54:48.256 : busy:heating
    > 12:54:48.449 : T:155.28 /240 @:255
    > 12:54:49.454 : T:158.71 /240 @:255
    > 12:54:50.259 : busy:heating
    > 12:54:50.452 : T:162.31 /240 @:255
    > 12:54:51.455 : T:165.82 /240 @:255
    > 12:54:52.258 : busy:heating
    > 12:54:52.454 : T:169.18 /240 @:255
    > 12:54:53.454 : T:172.82 /240 @:255
    > 12:54:54.256 : busy:heating
    > 12:54:54.457 : T:176.18 /240 @:255
    > 12:54:55.457 : T:179.55 /240 @:255
    > 12:54:56.259 : busy:heating
    > 12:54:56.456 : T:182.81 /240 @:140
    > 12:54:57.459 : T:186.74 /240 @:140
    > 12:54:58.258 : busy:heating
    > 12:54:58.459 : T:189.89 /240 @:140
    > 12:54:59.463 : T:192.78 /240 @:140
    > 12:55:00.257 : busy:heating
    > 12:55:00.462 : T:195.00 /240 @:140
    > 12:55:01.465 : T:197.50 /240 @:140
    > 12:55:02.255 : busy:heating
    > 12:55:02.465 : T:199.86 /240 @:140
    > 12:55:03.464 : T:201.53 /240 @:140
    > 12:55:04.258 : busy:heating
    > 12:55:04.468 : T:203.05 /240 @:140
    > 12:55:05.467 : T:204.58 /240 @:140
    > 12:55:06.257 : busy:heating
    > 12:55:06.470 : T:206.10 /240 @:140
    > 12:55:07.470 : T:207.63 /240 @:140
    > 12:55:08.259 : busy:heating
    > 12:55:08.471 : T:208.98 /240 @:140
    > 12:55:09.472 : T:210.00 /240 @:140
    > 12:55:10.259 : busy:heating
    > 12:55:10.472 : T:211.01 /240 @:140
    > 12:55:11.476 : T:212.32 /240 @:140
    > 12:55:12.256 : busy:heating
    > 12:55:12.475 : T:213.04 /240 @:140
    > 12:55:13.478 : T:213.62 /240 @:140
    > 12:55:14.255 : busy:heating
    > 12:55:14.477 : T:214.78 /240 @:140
    > 12:55:15.481 : T:215.80 /240 @:140
    > 12:55:16.259 : busy:heating
    > 12:55:16.481 : T:216.52 /240 @:140
    > 12:55:17.480 : T:217.10 /240 @:140
    > 12:55:18.258 : busy:heating
    > 12:55:18.484 : T:218.26 /240 @:140
    > 12:55:19.482 : T:218.70 /240 @:140
    > 12:55:20.259 : busy:heating
    > 12:55:20.482 : T:219.86 /240 @:140
    > 12:55:21.486 : T:221.67 /240 @:140
    > 12:55:22.259 : busy:heating
    > 12:55:22.485 : T:224.44 /240 @:140
    > 12:55:23.488 : T:227.22 /240 @:0
    > 12:55:24.257 : busy:heating
    > 12:55:24.487 : T:229.44 /240 @:140
    > 12:55:25.492 : T:230.31 /240 @:140
    > 12:55:26.255 : busy:heating
    > 12:55:26.490 : T:231.25 /240 @:140
    > 12:55:27.489 : T:231.56 /240 @:140
    > 12:55:28.259 : busy:heating
    > 12:55:28.492 : T:231.56 /240 @:140
    > 12:55:29.494 : T:232.50 /240 @:140
    > 12:55:30.257 : busy:heating
    > 12:55:30.496 : T:233.44 /240 @:140
    > 12:55:31.495 : T:234.06 /240 @:140
    > 12:55:32.256 : busy:heating
    > 12:55:32.495 : T:234.69 /240 @:140
    > 12:55:33.497 : T:235.63 /240 @:0
    > 12:55:34.259 : busy:heating
    > 12:55:34.497 : T:236.56 /240 @:0
    > 12:55:35.156 : ok 25
    > 12:55:35.156 : ok 26
    < 12:55:35.156 : N32 M105*22
    < 12:55:35.156 : N33 M117 ETE 5m 50s*78
    > 12:55:35.160 : ok 27
    > 12:55:35.161 : T:237.19 /240 @:0
    > 12:55:35.162 : ok 28
    > 12:55:35.162 : ok 29
    < 12:55:35.163 : N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:35.167 : N35 G1 X74.8 Y72.3 E5.35791*85
    > 12:55:35.172 : Error: value [0-255]
    > 12:55:35.173 : Resend:30
    > 12:55:35.195 : ok
    < 12:55:35.197 : Resend: N30 M117 ETE 5m 51s*76
    < 12:55:35.197 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:35.197 : Resend: N32 M105*22
    < 12:55:35.197 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:35.197 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:35.197 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    > 12:55:35.207 : Error: value [0-255]
    > 12:55:35.207 : Resend:30
    > 12:55:35.225 : ok
    > 12:55:36.225 : wait
    > 12:55:37.228 : wait
    > 12:55:38.228 : wait
    < 12:55:38.228 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:38.228 : N36 M105*18
    < 12:55:38.228 : N37 M117 ETE 5m 48s*67
    < 12:55:38.228 : N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:38.228 : N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:38.228 : N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:38.228 : N41 G1 X90.799 Y71.7 E9.83284*84
    > 12:55:38.237 : Error:expected line 30 got 36
    > 12:55:38.237 : Resend:30
    < 12:55:38.250 : Resend: N30 M117 ETE 5m 51s*76
    > 12:55:38.250 : ok
    < 12:55:38.250 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:38.250 : Resend: N32 M105*22
    < 12:55:38.250 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:38.250 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:38.250 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:38.250 : Resend: N36 M105*18
    > 12:55:38.257 : Error: value [0-255]
    > 12:55:38.257 : Resend:30
    > 12:55:38.271 : ok
    > 12:55:39.276 : wait
    > 12:55:40.276 : wait
    > 12:55:41.275 : wait
    < 12:55:41.275 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:41.275 : Resend: N37 M117 ETE 5m 48s*67
    < 12:55:41.275 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:41.275 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:41.275 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:41.275 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:55:41.275 : N42 M105*17
    > 12:55:41.284 : Error:expected line 30 got 37
    > 12:55:41.284 : Resend:30
    < 12:55:41.297 : Resend: N30 M117 ETE 5m 51s*76
    > 12:55:41.297 : ok
    < 12:55:41.297 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:41.297 : Resend: N32 M105*22
    < 12:55:41.297 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:41.297 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:41.297 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:41.297 : Resend: N36 M105*18
    > 12:55:41.305 : Error: value [0-255]
    > 12:55:41.305 : Resend:30
    > 12:55:41.319 : ok
    > 12:55:42.319 : wait
    > 12:55:43.323 : wait
    > 12:55:44.322 : wait
    < 12:55:44.322 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:44.322 : Resend: N37 M117 ETE 5m 48s*67
    < 12:55:44.322 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:44.322 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:44.322 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:44.323 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:55:44.323 : Resend: N42 M105*17
    > 12:55:44.331 : Error:expected line 30 got 37
    > 12:55:44.331 : Resend:30
    < 12:55:44.344 : Resend: N30 M117 ETE 5m 51s*76
    < 12:55:44.344 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:44.344 : Resend: N32 M105*22
    < 12:55:44.344 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:44.344 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:44.344 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:44.344 : Resend: N36 M105*18
    > 12:55:44.344 : ok
    > 12:55:44.352 : Error: value [0-255]
    > 12:55:44.352 : Resend:30
    > 12:55:44.366 : ok
    > 12:55:45.371 : wait
    > 12:55:46.374 : wait
    > 12:55:47.373 : wait
    < 12:55:47.373 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:47.373 : Resend: N37 M117 ETE 5m 48s*67
    < 12:55:47.373 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:47.373 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:47.373 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:47.373 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:55:47.373 : Resend: N42 M105*17
    > 12:55:47.382 : Error:expected line 30 got 37
    > 12:55:47.382 : Resend:30
    < 12:55:47.395 : Resend: N30 M117 ETE 5m 51s*76
    > 12:55:47.395 : ok
    < 12:55:47.395 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:47.395 : Resend: N32 M105*22
    < 12:55:47.395 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:47.395 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:47.395 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:47.395 : Resend: N36 M105*18
    > 12:55:47.402 : Error: value [0-255]
    > 12:55:47.402 : Resend:30
    > 12:55:47.416 : ok
    > 12:55:48.417 : wait
    > 12:55:49.421 : wait
    > 12:55:50.421 : wait
    < 12:55:50.421 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:50.421 : Resend: N37 M117 ETE 5m 48s*67
    < 12:55:50.421 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:50.421 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:50.421 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:50.421 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:55:50.421 : Resend: N42 M105*17
    > 12:55:50.430 : Error:expected line 30 got 37
    > 12:55:50.430 : Resend:30
    > 12:55:50.443 : ok
    < 12:55:50.443 : Resend: N30 M117 ETE 5m 51s*76
    < 12:55:50.443 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:50.443 : Resend: N32 M105*22
    < 12:55:50.443 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:50.443 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:50.443 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:50.443 : Resend: N36 M105*18
    > 12:55:50.450 : Error: value [0-255]
    > 12:55:50.450 : Resend:30
    > 12:55:50.464 : ok
    > 12:55:51.465 : wait
    > 12:55:52.468 : wait
    > 12:55:53.468 : wait
    < 12:55:53.468 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:53.468 : Resend: N37 M117 ETE 5m 48s*67
    < 12:55:53.468 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:53.468 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:53.468 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:53.468 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:55:53.468 : Resend: N42 M105*17
    > 12:55:53.476 : Error:expected line 30 got 37
    > 12:55:53.476 : Resend:30
    < 12:55:53.489 : Resend: N30 M117 ETE 5m 51s*76
    > 12:55:53.489 : ok
    < 12:55:53.489 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:53.489 : Resend: N32 M105*22
    < 12:55:53.489 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:53.489 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:53.489 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:53.489 : Resend: N36 M105*18
    > 12:55:53.497 : Error: value [0-255]
    > 12:55:53.497 : Resend:30
    > 12:55:53.511 : ok
    > 12:55:54.516 : wait
    > 12:55:55.516 : wait
    > 12:55:56.515 : wait
    < 12:55:56.515 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:56.515 : Resend: N37 M117 ETE 5m 48s*67
    < 12:55:56.515 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:56.515 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:56.515 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:56.515 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:55:56.515 : Resend: N42 M105*17
    > 12:55:56.523 : Error:expected line 30 got 37
    > 12:55:56.523 : Resend:30
    < 12:55:56.536 : Resend: N30 M117 ETE 5m 51s*76
    > 12:55:56.536 : ok
    < 12:55:56.536 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:56.536 : Resend: N32 M105*22
    < 12:55:56.536 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:56.536 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:56.536 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:56.536 : Resend: N36 M105*18
    > 12:55:56.544 : Error: value [0-255]
    > 12:55:56.544 : Resend:30
    > 12:55:56.559 : ok
    > 12:55:57.559 : wait
    > 12:55:58.563 : wait
    > 12:55:59.562 : wait
    < 12:55:59.562 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:55:59.562 : Resend: N37 M117 ETE 5m 48s*67
    < 12:55:59.562 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:55:59.562 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:55:59.562 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:55:59.562 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:55:59.562 : Resend: N42 M105*17
    > 12:55:59.571 : Error:expected line 30 got 37
    > 12:55:59.571 : Resend:30
    < 12:55:59.584 : Resend: N30 M117 ETE 5m 51s*76
    > 12:55:59.584 : ok
    < 12:55:59.584 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:55:59.584 : Resend: N32 M105*22
    < 12:55:59.584 : Resend: N33 M117 ETE 5m 50s*78
    < 12:55:59.584 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:55:59.584 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:55:59.584 : Resend: N36 M105*18
    > 12:55:59.592 : Error: value [0-255]
    > 12:55:59.592 : Resend:30
    > 12:55:59.606 : ok
    > 12:56:00.611 : wait
    > 12:56:01.610 : wait
    > 12:56:02.614 : wait
    < 12:56:02.614 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:56:02.614 : Resend: N37 M117 ETE 5m 48s*67
    < 12:56:02.614 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:56:02.614 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:56:02.614 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:56:02.614 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:56:02.614 : Resend: N42 M105*17
    > 12:56:02.623 : Error:expected line 30 got 37
    > 12:56:02.623 : Resend:30
    < 12:56:02.636 : Resend: N30 M117 ETE 5m 51s*76
    > 12:56:02.636 : ok
    < 12:56:02.636 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:02.636 : Resend: N32 M105*22
    < 12:56:02.636 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:02.636 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:02.636 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:02.636 : Resend: N36 M105*18
    > 12:56:02.644 : Error: value [0-255]
    > 12:56:02.644 : Resend:30
    > 12:56:02.658 : ok
    > 12:56:03.662 : wait
    > 12:56:04.661 : wait
    > 12:56:05.661 : wait
    < 12:56:05.661 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:56:05.661 : Resend: N37 M117 ETE 5m 48s*67
    < 12:56:05.661 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:56:05.661 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:56:05.661 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:56:05.661 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:56:05.661 : Resend: N42 M105*17
    > 12:56:05.670 : Error:expected line 30 got 37
    > 12:56:05.670 : Resend:30
    < 12:56:05.683 : Resend: N30 M117 ETE 5m 51s*76
    > 12:56:05.683 : ok
    < 12:56:05.683 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:05.683 : Resend: N32 M105*22
    < 12:56:05.683 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:05.683 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:05.683 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:05.683 : Resend: N36 M105*18
    > 12:56:05.690 : Error: value [0-255]
    > 12:56:05.690 : Resend:30
    > 12:56:05.704 : ok
    > 12:56:06.706 : wait
    > 12:56:07.708 : wait
    > 12:56:08.708 : wait
    < 12:56:08.708 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:56:08.708 : Resend: N37 M117 ETE 5m 48s*67
    < 12:56:08.708 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:56:08.708 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:56:08.708 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:56:08.708 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:56:08.708 : Resend: N42 M105*17
    > 12:56:08.717 : Error:expected line 30 got 37
    > 12:56:08.717 : Resend:30
    < 12:56:08.730 : Resend: N30 M117 ETE 5m 51s*76
    > 12:56:08.730 : ok
    < 12:56:08.730 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:08.730 : Resend: N32 M105*22
    < 12:56:08.730 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:08.730 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:08.730 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:08.730 : Resend: N36 M105*18
    > 12:56:08.737 : Error: value [0-255]
    > 12:56:08.737 : Resend:30
    > 12:56:08.751 : ok
    > 12:56:09.756 : wait
    > 12:56:10.756 : wait
    > 12:56:11.759 : wait
    < 12:56:11.759 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:56:11.759 : Resend: N37 M117 ETE 5m 48s*67
    < 12:56:11.759 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:56:11.759 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:56:11.759 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:56:11.759 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:56:11.759 : Resend: N42 M105*17
    > 12:56:11.768 : Error:expected line 30 got 37
    > 12:56:11.768 : Resend:30
    < 12:56:11.781 : Resend: N30 M117 ETE 5m 51s*76
    > 12:56:11.781 : ok
    < 12:56:11.781 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:11.781 : Resend: N32 M105*22
    < 12:56:11.781 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:11.781 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:11.781 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:11.781 : Resend: N36 M105*18
    > 12:56:11.789 : Error: value [0-255]
    > 12:56:11.789 : Resend:30
    > 12:56:11.803 : ok
    > 12:56:12.808 : wait
    > 12:56:13.807 : wait
    > 12:56:14.734 : ok
    < 12:56:14.734 : Resend: N37 M117 ETE 5m 48s*67
    > 12:56:14.742 : Error:expected line 30 got 37
    > 12:56:14.742 : Resend:30
    < 12:56:14.755 : Resend: N30 M117 ETE 5m 51s*76
    > 12:56:14.755 : ok
    < 12:56:14.755 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:14.755 : Resend: N32 M105*22
    < 12:56:14.755 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:14.755 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:14.755 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:14.755 : Resend: N36 M105*18
    > 12:56:14.967 : Resend:30
    > 12:56:14.981 : ok
    > 12:56:15.986 : wait
    > 12:56:16.985 : wait
    > 12:56:17.985 : wait
    < 12:56:17.985 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:56:17.985 : Resend: N37 M117 ETE 5m 48s*67
    < 12:56:17.985 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:56:17.985 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:56:17.985 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:56:17.985 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:56:17.985 : Resend: N42 M105*17
    > 12:56:17.994 : Error:expected line 30 got 37
    > 12:56:17.994 : Resend:30
    < 12:56:18.007 : Resend: N30 M117 ETE 5m 51s*76
    > 12:56:18.007 : ok
    < 12:56:18.007 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:18.007 : Resend: N32 M105*22
    < 12:56:18.007 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:18.007 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:18.007 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:18.007 : Resend: N36 M105*18
    > 12:56:18.014 : Error: value [0-255]
    > 12:56:18.014 : Resend:30
    > 12:56:18.028 : ok
    > 12:56:19.030 : wait
    > 12:56:20.032 : wait
    > 12:56:21.032 : wait
    < 12:56:21.032 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:56:21.032 : Resend: N37 M117 ETE 5m 48s*67
    < 12:56:21.032 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:56:21.032 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:56:21.032 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:56:21.032 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:56:21.032 : Resend: N42 M105*17
    > 12:56:21.041 : Error:expected line 30 got 37
    > 12:56:21.041 : Resend:30
    > 12:56:21.054 : ok
    < 12:56:21.054 : Resend: N30 M117 ETE 5m 51s*76
    < 12:56:21.054 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:21.054 : Resend: N32 M105*22
    < 12:56:21.054 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:21.054 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:21.054 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:21.054 : Resend: N36 M105*18
    > 12:56:21.269 : Resend:30
    > 12:56:21.283 : ok
    > 12:56:22.285 : wait
    > 12:56:23.289 : wait
    > 12:56:24.288 : wait
    < 12:56:24.288 : Warning: Seems like we missed a ok, got a wait - continue sending.
    < 12:56:24.288 : Resend: N37 M117 ETE 5m 48s*67
    < 12:56:24.288 : Resend: N38 G0 X74.2 Y71.7 F2820*125
    < 12:56:24.288 : Resend: N39 G1 X74.2 Y93.299 E6.97428 F1080*56
    < 12:56:24.288 : Resend: N40 G1 X90.799 Y93.299 E8.21647*94
    < 12:56:24.288 : Resend: N41 G1 X90.799 Y71.7 E9.83284*84
    < 12:56:24.288 : Resend: N42 M105*17
    > 12:56:24.297 : Error:expected line 30 got 37
    > 12:56:24.297 : Resend:30
    > 12:56:24.310 : ok
    < 12:56:24.310 : Resend: N30 M117 ETE 5m 51s*76
    < 12:56:24.310 : Resend: N31 G1 X90.199 Y92.699 E2.67895*82
    < 12:56:24.310 : Resend: N32 M105*22
    < 12:56:24.310 : Resend: N33 M117 ETE 5m 50s*78
    < 12:56:24.310 : Resend: N34 G1 X90.199 Y72.3 E4.20552*95
    < 12:56:24.310 : Resend: N35 G1 X74.8 Y72.3 E5.35791*85
    < 12:56:24.310 : Resend: N36 M105*18
    > 12:56:24.318 : Error: value [0-255]
    > 12:56:24.318 : Resend:30
    > 12:56:24.332 : ok
    > 12:56:25.333 : wait
    < 12:56:26.897 : Printer reset detected - initalizing
    > 12:56:26.897 : start
    > 12:56:26.909 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    > 12:56:26.913 : Free RAM:3191
    > 12:56:26.915 : SelectExtruder:0
    > 12:56:26.919 : FlowMultiply:100
    < 12:56:27.049 : N1 M110*34
    < 12:56:27.049 : N2 M115*36
    < 12:56:27.049 : N3 M105*36
    < 12:56:27.049 : N4 M114*35
    > 12:56:27.052 : ok
    > 12:56:27.052 : ok 2
    < 12:56:27.064 : CncPlugin: Change step size to 1 mm
    < 12:56:27.065 : N5 M111 S15*80
    < 12:56:27.065 : N6 T0*60
    < 12:56:27.065 : N7 M107*34
    < 12:56:27.065 : N8 M80*19
    < 12:56:27.071 : N9 M220 S100*104
    < 12:56:27.071 : N10 M221 S100*81
    > 12:56:27.085 : FIRMWARE_NAME:BoXZY_Repetier_0.92.9 FIRMWARE_URL:https://github.com/dewhisna/Repetier-Firmware/tree/BoXZY_Custom PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    < 12:56:27.085 : N11 M111 S15*101
    > 12:56:27.085 : Printed filament:21.23m Printing time:0 days 14 hours 38 min
    > 12:56:27.085 : PrinterMode:FFF
    > 12:56:27.085 : ok 3
    < 12:56:27.089 : N12 T0*9
    > 12:56:27.089 : T:240.38 /0 @:0
    > 12:56:27.089 : ok 4
    > 12:56:27.089 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    > 12:56:27.089 : ok 5
    > 12:56:27.089 : DebugLevel:15
    > 12:56:27.090 : TargetExtr0:0
    > 12:56:27.090 : Echo:N5 M111  S15
    > 12:56:27.090 : ok 6
    > 12:56:27.091 : SelectExtruder:0
    > 12:56:27.098 : FlowMultiply:100
    > 12:56:27.099 : Echo:N6 T0
    > 12:56:27.099 : ok 7
    > 12:56:27.099 : Echo:N7 M107
    > 12:56:27.099 : ok 8
    > 12:56:27.099 : Echo:N8 M80
    > 12:56:27.099 : ok 9
    > 12:56:27.099 : SpeedMultiply:100
    > 12:56:27.099 : Echo:N9 M220  S100
    > 12:56:27.099 : ok 10
    > 12:56:27.102 : FlowMultiply:100
    > 12:56:27.102 : Echo:N10 M221  S100
    > 12:56:27.102 : ok 11
    > 12:56:27.106 : DebugLevel:15
    > 12:56:27.106 : TargetExtr0:0
    > 12:56:27.106 : Echo:N11 M111  S15
    > 12:56:27.110 : ok 12
    > 12:56:27.110 : SelectExtruder:0
    > 12:56:27.111 : FlowMultiply:100
    > 12:56:27.114 : Echo:N12 T0
    < 12:56:27.270 : N13 M105*21
    > 12:56:27.274 : ok 13
    > 12:56:27.275 : T:240.38 /0 @:0
    > 12:56:27.278 : Echo:N13 M105
    > 12:56:27.512 : BoXZY 3D Printer Head detected
    > 12:56:28.274 : wait
    > 12:56:29.272 : wait
    > 12:56:30.276 : wait
    < 12:56:30.334 : N14 M105*18
    > 12:56:30.337 : ok 14
    > 12:56:30.338 : T:241.15 /0 @:0
    > 12:56:30.341 : Echo:N14 M105
    < 12:56:31.230 : N15 G28 Z0*109
    > 12:56:31.234 : ok 15
    < 12:56:31.947 : N16 G1 Z100*84
    > 12:56:32.771 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    > 12:56:32.771 : Echo:N15 G28  Z0.00
    > 12:56:32.771 : ok 16
    > 12:56:32.775 : Echo:N16 G1  Z100.00
    < 12:56:33.396 : N17 M105*17
    > 12:56:33.401 : ok 17
    > 12:56:33.401 : T:239.38 /0 @:0
    > 12:56:33.401 : Echo:N17 M105
    < 12:56:34.162 : N18 G28 X0*98
    > 12:56:34.167 : ok 18
    < 12:56:34.683 : N19 G28 Y0*98
    > 12:56:36.166 : busy:processing
    < 12:56:36.456 : N20 M105*21
    > 12:56:38.165 : busy:processing
    < 12:56:39.523 : N21 M105*20
  • Try disabling "Send ETA to printer display" in printer settings. I think that gets parsed wrong causing the error.
    Oh this time it really works !!!!! Really appreciate the help, finally can print without any problem. Thanks !!!!!!!!
  • I hate to ressurect this dead thread, but....I had a print going and forgot to turn off sleep setting on laptop and the unit went crazy and i had one hell of a mess. has not worked correctly since. I can activate heater via manual controls but when i try to print, heater will not turn on. i have uninstalled and reinstalled software, still nothing. i have been through all of the settings and it appears to me if all is correct......PLEASE HELP
  • Bottom of 'manual control' tab, make sure dry run is off.
