ultratronics pro v1 sd card
Hi, since the SD card is used as an eeprom for the ultratronics, how do I print using the sd card slot? Or if that is not possible, what is the easiest way to load a stl file in my printer, without it being directly connected to anything?
  • As long as you do not modify eeprom I think it is ok to also use it for printing. Only thing is you need to make sure sd card is inserted when you power on printer since then the eeprom is read.
