Cura not slicing
I use Cura inside Repetier 2.0.5 and just suddenly it stopped slicing. I have deinstalled and reinstalled Repetier and nothing changed. Slic3r slices as usual.
I use WIN 7/32 bit for Repetier.
  • See in working directory. There is a CuraEngine folder. Uninstalling does not delete it and there your settings are stored. My guess is that you made some settings causing the problem. So deleting the folder and recreating them should work if you do not copy that error.
