G28 check
Is it possible to add a function to check if the machine skipped a step.
For example every 10 slices, a function would be included into the program. Then the machine check for X end stop contact. If X end stop is detected at X higher than 0,5mm or lower than -0,5mm then error and stop cycle
After same with Y.
I guess a function should be added into marlin?
May be there is one already?
At least is it possible to call a G code every 10 slices?
  • You would need to add a postprocessor doing this.
    Slic3r has a layer switch gcode I think. But every layer would be time consuming.
    I'm not aware of such a function.
