Eprom Config greyed out
I'm running Repetier-Host v 2.0.1, Anet A8 with original firmware. Trying to list Eprom config under the Config Tab. That option is greyed out. Why?
  • It doe snot detect it as marlin clone since it does not contain the marlin id string. I thought I had added it to the list for 2.0.1, but maybe there exist different strings. What does M115 return in log? When I know that I can add it for next release.
  • Can you advise if this was sorted. I have same issue with Repetier Host 2.05.
  • I had added "anet" as detection string. If they have again changed the firmware identifier reported on M115 if is of course again broken. What does it return on M115 in your case.
