Auto levelling grid - not square?
I've just started looking at the auto leveling options.
G32 with "BED_LEVELING_METHOD 0" operates as expected, probing the 3 defined points.
But when I change to "BED_LEVELING_METHOD 1" the grid is not as shown in the documents, more like a parallelogram where X and Y get shifted in proportion upon each probe event. Basically my rear left corner and front right corner do not get probed?
Is there a setting I have wrong somewhere, I would have expected the probe would do a column of Y points, then index to the next X point?
Thanks,
Ray
  • sounds like incorrect X Y values in either P1 P2 or P3 probing locations, check the values stored in the eeprom.
  • edited January 2018
    Thanks Martin, right on the money.
    I had:
    P1 30,20
    P2 220,20
    P3 145, 220
    which was perfect for mode 0 as they were near the leveling points.
    I didn't realise that P3 was important for the grid! (obvious now in the diagram :-/ )
    Changing P3 to 30,220 makes mode 1 work as expected.
    Thanks again.
    Ray
