Send Notification on Layer x
I'm not sure if this functionality exists currently, but I would like to have a notification sent when the print reaches a specified layer.
I know you can have a a notification sent when the printer receives a Pause command, but I would like to receive a notification when the print reaches a specific layer without having to issue a Pause.
  • No, host can't. However if you print using repetier-server you can.
    Add
    ;@pushmessage some text
    and you will get a message once that command is being processed. And host can print using the server.
  • Excellent, I think this will work for what I wanted. Thank you.
