Z-height determined pause
I would like to see a feature added that lets you pick a Z-height or layer, then the software would find a spot in the middle of the infill (for the prevention of globs) to allow for a filament swap
  • You can do that already. Open g-code editor. Select at bottom a layer and git button on the left to go to layer. You see now Z height and can correct. Select show single layer and start marking lines with shift+cursor down/page down. You see gcode marked in yellow in the preview. Go until you reach infill or position you like and then add
    ;@pause message
