Rostock Max V2/ramb0 with the Prometheus System.
I've been trying to get V0.92.2 working with dual extruders and single hotend for about a month. Every time i try and switch to E1 in S3D or any other slicer software, it completely locks up and has to be power cycled. I did have some success with V0.91S. So I did try the configuration tool on the Repetier web site. I copied all the settings that worked on V0.91S AND even hooked up a Reprap Full Discount Graphics LCD and WOW it came up. BUT, it didn't move like it should. When I tried to home it, it would go home then back down to about 200mm from the bed. Also, if I tried to move the axis, it would move 20mm or so when the screen would say 1.0mm When I tried to heat up the bed and hotend i got nothing.  I double check all the steps per mm and the pins.h file all match what I had on V0.91S.
I'd like to set up inductive mesh probing also.
Any help would be great!!
