Updating CuraEngine
Is there a way to update the CuraEngine slicer that came with Repetier-Host?  I'm on Windows 7 64-bit and I'm running version 2.0.5 of Repetier-Host.  It seems that this Cura does not have many options as far as infill patterns.  Am I just missing something?  Under the Structures tab all I see is Automatic, Grid, Lines, & Concentric Lines.
  • We are using latest compatible version already. Newer versions use a very complicated and different config system so we can not use them.
  • Ok, thank you.  I just wanted to make sure I wasn't overlooking something.
