slicer to print errors
using slicer prusa or regular slic3r, when i set values under configuration, settings will not save , have to manually edit g code, then print but settings are not transferring to manual print controls, also no log is showing, but i can kill print and adjust settings (example turn off and on extruder)
  • You must save with the save button in slic3r and then reslice in repetierhost. Gcode is not automatically changed!
  • have done that , once i hit print , the only setting that will work under the manual control tab is for the hot end(turn on , turn off, adjust temperature) on the other hand if i do not print anything and i am in the manual control settings , i can adjust everything , and it all functions fine, i have a gt2560 board running marlin 1.0.6
