speed FILAMENTCHANGE
how to change the speed in FILAMENT CHANGE mode.
I need to slow down, change FILAMENT, where do I find this parameter?
  • The speeds defined also for G10/G11 are used here. So enable that feature and edit the config values.
  • I proexperimented with G10 g11. not exactly what you need!
  • is there a line in the code that is responsible for the rate of change of filament
  • In extruder.cpp
    void Extruder::retractDistance(float dist, bool extraLength) {
        float oldFeedrate = Printer::feedrate;
        int32_t distance = static_cast<int32_t>(dist * stepsPerMM / Printer::extrusionFactor);
        int32_t oldEPos = Printer::currentPositionSteps[E_AXIS];
        float speed = distance > 0 ? EEPROM_FLOAT(RETRACTION_SPEED) : EEPROM_FLOAT(RETRACTION_UNDO_SPEED);
    #if MIXING_EXTRUDER
        if(!extraLength)
            Printer::setAllEMotors(true);
    #endif
        PrintLine::moveRelativeDistanceInSteps(0, 0, 0, -distance, RMath::max(speed, 1.f), false, false);
    #if MIXING_EXTRUDER
        if(!extraLength)
            Printer::setAllEMotors(false);
    #endif
        Printer::currentPositionSteps[E_AXIS] = oldEPos; // restore previous extruder position
        Printer::feedrate = oldFeedrate;
    especially
    where you see the 2 values from G10/G11 config. But also see that they are stored to eeprom so you need to change them there.
