running from sd card
ran a program from the sdcard ramps 1.4 full display with sdcard and corexy home yxz
when it finished it homed but to x rather then Y never homes when on usb
for some reason it wanted to go to X after it finished
my x needs to be homed 2nd hence the yxz (this is due to having to lengthen the x access )
is something different or need to update on the display control side?
  • Check your end gcode you put on sd card. From sd print it only executes what is in the file, so if it doe sit wrong then only because you have wrong commands at the end of gcode and you need to configure your slicer to insert the right one.
  • OK thanks will check that out :>)
