Z probing offset when printing
Hello!
I`m implementing auto leveling in my MP maker select v2.
Works fine, capture the potins and so, but when the print start it prints with an offset of the bed that I`m having trouble to correct.
Any help is welcome!
thanks!:)
  • Normally an offset indicates wrong z-probe height during probing, resulting in correct rotation but wrong distance.
    Hello!
    I tried and in the log list in repetier host shows this message:
    "Z jerk was too low, setting to 0.71"
    but still printing with an offset =/
    I`m using the following code:
    #define ENDSTOP_PULLUP_Z_MIN false //was true
    #define min_software_endstop_z true
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 180
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_PERMANENT 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 900L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 20
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 5
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define DOUBLE_STEP_DELAY 1 // time in microseconds
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 800
    #define MAX_JERK 10
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1  //was 0
    #define Z_PROBE_BED_DISTANCE 0
    #define Z_PROBE_PIN 20 // was -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET -45
    #define Z_PROBE_Y_OFFSET -45
    #define Z_PROBE_SPEED 1.5
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 1.5
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_HEIGHT -1
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 130
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    Thanks!! :)
  • The warning is not related to your problem. It is just a contarint to ensure correct motor timings.
    is what we are talking about. -1 means that when triggering the nozzle is 1mm below the bed, so makes normally no sense. Please note that this value is stored in eeprom and you need to change it there, not in the configuration. Use host/server eeprom editor to change.
    Ok!
    I got better results, but not there yet... =/
    it`s measuring the bed and still with an offset and not correcting the level of the bed as it prints...
    I have recorded what's happening...
    Thanks!! :)
  • What commands did you send and what did the log say? It looks like you did not home but use G32 only, whcih is a different process also both should set Z at the end.
    In your mode it will also go up "bed coating" mm. So make sure to have it on 0 to have your blue tape as reference.
  • edited September 2017
    I sent this codes.
    and, bed coating = 0mm.
    ; Default start code
    G28
    G29
    G1 Z15 F{Z_TRAVEL_SPEED}
    M107 ; Turn off fan
    G90 ; Absolute positioning was 90
    M82 ; Extruder in absolute mode
    {IF_BED}M190 S{BED}
    ; Activate all used extruder
    {IF_EXT0}M104 T0 S{TEMP0}
    G92 E0 ; Reset extruder position
    ; Wait for all used extruders to reach temperature
    {IF_EXT0}M109 T0 S{TEMP0}
    Now I tried the G32 and removed the G29 before the print and its looking good :)
  • Thanks You Very Much!!!!
    I got it right! the ABL is working, and the print processes is going very well!
