Filament change
edited August 2017 in Questions & Answers
The filament shift, Z axis goes to 0
Resulting in plastic accumulation fused under nozzle
Where it is possible to change the setting
Only when the system is switched on
  • Only when the system is switched on for the first time
  • I don't think we are sending z position at all for filamentchange. It might come from firmware aswedo not send z it might use last z which then seems 0 in firmware also if it is at a fifferent level. You could check in log which commands got send so it is more clear why it happens.
  • edited August 2017
    These are the commands
    Use only for changing the ABS-PLA-PETG coil
    Not during printing
    My fast length is 750 mm
    Slow 18 mm
    N20 G1 X0.00 Y0.00 F2400
    > 22:47:31.311: ok 20
    < 22:47:31.311: N21 G1 Z0.00 F2400
    > 22:47:31.313: ok 21
    < 22:47:31.313: N22 G1 E50.00 F2400
    > 22:47:31.315: ok 22
    < 22:47:31.315: N23 G1 X0.00 Y0.00 F2400
    > 22:47:31.317: ok 23
    < 22:47:31.317: N24 G1 Z0.00 F2400
    > 22:47:31.319: ok 24
    < 22:47:31.319: N25 G1 E100.00 F2400
    > 22:47:31.321: ok 25
    < 22:47:31.321: N26 G1 X0.00 Y0.00 F2400
    > 22:47:31.324: ok 26
    < 22:47:31.324: N27 G1 Z0.00 F2400
    > 22:47:31.326: ok 27
    < 22:47:31.326: N28 G1 E150.00 F2400
    > 22:47:31.328: ok 28
    < 22:47:31.328: N29 G1 X0.00 Y0.00 F2400
    > 22:47:31.330: ok 29
    < 22:47:31.330: N30 G1 Z0.00 F2400
    > 22:47:31.332: ok 30
    < 22:47:31.332: N31 G1 E200.00 F2400
    > 22:47:31.334: ok 31
    < 22:47:31.334: N32 G1 X0.00 Y0.00 F2400
    > 22:47:31.337: ok 32
    < 22:47:31.337: N33 G1 Z0.00 F2400
    > 22:47:31.339: ok 33
    < 22:47:31.339: N34 G1 E250.00 F2400
    > 22:47:31.341: ok 34
    < 22:47:31.341: N35 G1 X0.00 Y0.00 F2400
    > 22:47:31.343: ok 35
    < 22:47:31.343: N36 G1 Z0.00 F2400
    > 22:47:31.345: ok 36
    < 22:47:31.345: N37 G1 E300.00 F2400
    > 22:47:31.347: ok 37
    < 22:47:31.348: N38 G1 X0.00 Y0.00 F2400
    > 22:47:31.350: ok 38
    < 22:47:31.350: N39 G1 Z0.00 F2400
    > 22:47:31.352: ok 39
    < 22:47:31.352: N40 G1 E350.00 F2400
    > 22:47:31.354: ok 40
    < 22:47:31.354: N41 G1 X0.00 Y0.00 F2400
    > 22:47:31.356: ok 41
    < 22:47:31.357: N42 G1 Z0.00 F2400
    > 22:47:31.359: ok 42
    < 22:47:31.359: N43 G1 E400.00 F2400
    > 22:47:31.361: ok 43
    < 22:47:31.361: N44 G1 X0.00 Y0.00 F2400
    > 22:47:31.363: ok 44
    < 22:47:31.363: N45 G1 Z0.00 F2400
    > 22:47:31.365: ok 45
    < 22:47:31.365: N46 G1 E450.00 F2400
    > 22:47:31.367: ok 46
    < 22:47:31.367: N47 G1 X0.00 Y0.00 F2400
    > 22:47:31.370: ok 47
    < 22:47:31.370: N48 G1 Z0.00 F2400
    > 22:47:31.372: ok 48
    < 22:47:31.372: N49 G1 E500.00 F2400
    > 22:47:31.374: ok 49
    < 22:47:31.374: N50 G1 X0.00 Y0.00 F2400
    > 22:47:31.376: ok 50
    < 22:47:31.376: N51 G1 Z0.00 F2400
    > 22:47:31.378: ok 51
    < 22:47:31.378: N52 G1 E550.00 F2400
    > 22:47:31.380: ok 52
    < 22:47:31.380: N53 G1 X0.00 Y0.00 F2400
    > 22:47:31.383: ok 53
    < 22:47:31.383: N54 G1 Z0.00 F2400
    > 22:47:31.385: ok 54
    < 22:47:31.385: N55 G1 E600.00 F2400
    > 22:47:31.387: ok 55
    < 22:47:31.387: N56 G1 X0.00 Y0.00 F2400
    > 22:47:31.389: ok 56
    < 22:47:31.389: N57 G1 Z0.00 F2400
    > 22:47:31.391: ok 57
    < 22:47:31.391: N58 G1 E650.00 F2400
    > 22:47:31.393: ok 58
    < 22:47:31.393: N59 G1 X0.00 Y0.00 F2400
    > 22:47:31.396: ok 59
    < 22:47:31.396: N60 G1 Z0.00 F2400
    > 22:47:31.545: ok 60
    < 22:47:31.545: N61 G1 E700.00 F2400
    > 22:47:31.547: ok 61
    < 22:47:31.547: N62 G1 E750.00 F2400
    > 22:47:31.549: ok 62
    < 22:47:31.549: N63 G1 E768.00 F120
    > 22:47:31.552: ok 63
  • Looks like server is comstntly sending positions. Is not what i wanted. Have to look into the sources when i'm back.
  • I have checked the code and in the current version filamentchange does not move the extruder at all. Are you using an older version then 0.86.2 ?
  • I'm always upgraded to last version
  • Do you have any filament related scrips in server that would explain the coordinates?
