Installed on DaVinci 1.0a - Motors, Light, Headed bed will not work
Simply, how do I edit the firmware and change numbers?
Now, the long explination...
I am using the DaVinci fork of repetier from here.
I failed my first few attempts at flashing, and got the "black bars". I uninstalled/re-installed Arduino software (which I had been using for other Arduino projects for years) and then the firmware installed perfectly.
I changed the DaVinci settings, in firmware,  as follows:
#define DAVINCI 1// "0" if not DAVINCI, "1" For DAVI...
#define MODEL  1//"0" for first generation (jumper JP1...
#define REPURPOSE_FAN_TO_COOL_EXTRUSIONS 0 //Setting this to 1 will repurpo...
                                           //Warning: for DaVinci 1.0 need to add a permanent fan with power supply to cool extruder
This post seems to have my same problem:
http://forum.repetier.com/discussion/3938/davinci-1-0a-motors-not-moving/p1
The post describes zero's in the firmware being the problem, and gives numbers to replace the zero's.
How do I access the firmware and edit the zero's?
  • You open the sources, edit required setting and compile and upload it again using the Arduino IDE.
