Servo and microswitch bed leveling
When bed leveling is done with a microswitch mounted on a servo is it possible to to deploy the servo before each test position and then retract it between test positions. I notice that this was done in the earliest videos of bed leveling - although illogical I do have a particular need to do it this way.
Mike
  • Currently it is not possible. YOu can easily add the commands in bedleveling.cpp in runzprobe at the correct position.
