Not uploading after making change in Frimware
Hi
I do not have heated bed on Repetier host.
#define HAVE_HEATED_BED 0
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
 made the change
#define HAVE_HEATED_BED 1
I can not upload it now
I appreciate if someone can help me
  • Would help where the problem is and what the error message is.
  • Hi ,
    Thanks for your answer. There is no error message. I changed the 0 to 1 , saved and compiled , Then tried to upload  . It never completed compiling even I waited for half an hour , no error message
    Thanks agian
  • See output window in arduino ide on whats going on. If it is compiler never completing try reinstalling arduino ide. Sometimes a reboot or reconnect of usb to printer helps.
