Print not printing?
Hello! I am trying to print directly from USB and when I press Start Print, it immediately says: Print Job Finished. Any Ideas?
  • You need to slice the object before you print or load a sliced model. Otherwise your print contains no g-code (the commands to control printer) and print is in deed directly finished.
  • Oh @Repetier alright, question: I have not 3D printed in a long time but how do I change temp. settings in Repetier? I do not see them anywhere
  • You mean for slicing? In slicer settings is a filament section to set temperatures. Manually in manual control tab.
