Printer not printing!
Hi, I've recently purchased a new board for my printer, and everything works, including manual control, however when I come to print it, it moves to the endstops but doesn't print, but it says so on the repetier host.
I am getting this error
11:24:50.849 : Error:Printer set into dry run mode until restart!
As well as:
11:24:59.203 : Other:: working marked decoupled
bed and everything heats up and works correctly
Any suggestions?
  • Look earlier in the log. Your extruder seems to trigger the decoupled test. So it is either configured wrong or it heats slower then assumed and you need to increase decouple time for that. Log should show more info at the time decoupling is detected.
    Where can I chage these settings?
  • In our online config tool or configuration.h directly.
    what do i need to change?
  • Decouple test period / EXT0_DECOUPLE_TEST_PERIOD would be my guess.
