Z Axis moves very slowly but settings should be fine
i have installed the firmware and copied over the settings from marlin and the x and y axis moves great but the z Axis just moves ever so slowly i have a max speed set as 200mms and the steps per mm is 80 but it just moves so slowly
its barely noticeable apart from seeing the thread pulse round
  • What type and size threaded rod is on the Z axis ?
    Sounds like your Z steps/mm are far to low.
