Delta Print Resume Error - Moves Up Towers
We are running the latest versions of Repetier Server (0.80.3) on a custom Delta printer similar to a Kossel and have been experiencing some strange behavior while pausing and resuming a print. The pause function seems to work well but when resuming all towers slowly move all the way up until endstops are triggered and then it seemingly continues running the g-code.
We have experimented with added custom g-code scripts to the pause and resume and they seem to work fine but still exhibits the strange resume functionality.
I will see if I can get a video created but figure dI would go ahead and post in case any other have experienced this issue.
Thanks!
  • If you do please also enable log soy ou can see what got send to the printer at that time causing the move.
