Mac - Slicing
Is there a way to get another slicer besides slic3r or skeinforge for the mac Repetier Host? I have tried Cura externally then importing G-codes but they’re way off centre and a nightmare to sort out, same with Kisslicer… Is there a way to make them work internally in Repetier?? Or can someone help sort this out? Thanks.
  • No, only these two are implemented. All you can do is using a new Slic3r version.
    In external slicers you need to define the geometry to match yours. Especially where the center is differs depending on size and where the lower left edge is.
